k, i have this picture: i need 2 know the name of the site that is in this picture, but the problem is that the 1 that sent it to me for some idiotic reason has "blocked" the name of the site with this black thing in "paint" (the app that comes with windows). so i was wondering, can any1 plz fix that and then tell me how 2 do it? i mean can any1 remove this black thing and "restore" the image before it was marked with this black thing? BTW, im sorry for my bad english but im from ASIA, not speak a lot of english here.
simple answer is no, you can't undo what he did. The easiest way would be to figure it out using some detective work. IE: the font looks hebrew or maybe arabic... then start googling what it says...
I don't think there's much that can be done, but it looks as though it's something to do with P2P, not that that's going to narrow it down a whole lot... - H.
This is probably your only shot. Just google everything it says in those 5 tabs, and see if it comes up with any matches.
more then 500 matches. it will take me all day to go over all of them. r u 100% sure that this can't be fixed in photoshop? is there a photoshop site that u can direct me 2?
you cant undo it, as the image is saved as one layer. so you remove the black stuff and you will be left with nothing underneath.
well thats all i can do. any help?? edit :: middle tab is bit-techs forum (im shore you already know that)
that is either pure fluke or you have wayyyyyyyy to much time on your hands.......unless your a modern age sherlock holmes!? *insert pipe smoking smilie whilst wearing funny hat here*
he probbaly did this http://www.google.com/search?q=bitt...lr=lang_iw&newwindow=1&safe=off&output=search
I don't think posting a link to a website relating to warez will earn u many brownie points amongst the admins.
...The most obvious question is why in the f**k would you're mate send you a pic of a website, with everything painted out...
