Graphics I whoopsed, now my 8800gt is borked, any ideas.
Discussion in 'Hardware' started by unknowngamer, 15 Sep 2009.
  1. unknowngamer
    unknowngamer here
    3 Apr 2009
    It's one of these, but using the zalamn flower cooler without heatpipes (bigger)
    I put a gpu water block on and it was fine.
    Swapped back.
    Now my whoops was....
    I plugged the 2pin fan into the 2 pin HDMI audio header.
    (I fitted it rotated 90 degs anticlockwise, you can see how the fins would hide the header.)
    yeah, stupidz
    In my defense, the flower cooler obstructs the fan header and I didnt see it, and, the audio and fan headers are exactly the same shape connector.
    Anyway
    I plugged it in and started it up in the wrong header.
    I clocked the fan wasnt spinning quite quick, shut down and removed it, THEN spotted the correct header.
    Card isn't picked up in windows or dos (tried to use nvflash and it didnt see it either)
    So anything to try before this officially becomes an expensive paperweight.
    Thanks.
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    XD well least you won't do that again
  3. trig
    trig god's little mistake
    10 Aug 2006
    it's official...lol
    but hey, good excuse to grab a new card...
