Build Advice i3 or phenom
Discussion in 'Hardware' started by xxxsonic1971, 11 Jun 2013.
  1. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    hiya,
    i'm building a little system for my sisters kid just for gaming, he has all parts except cpu and mobo, he has about £150 to spend, the choice seems to be i3 or phenom, but what one is best for just playing games???
    cheers.
  2. Parge
    16 Jul 2010
    Hard to say, probably depends what games you are going with, personally I'd go with the Phenom, just because it has 4 cores, can be OC'd and is available for about £65
  3. mrbungle
    20 Sep 2004
    For that budget think you can prob pick up a FX6300 and ok motherboard new, failing that Id get a 2nd hand 2500K and Z series chipset motherboard, they go for peanuts 2nd hand the Z68 ones.
  4. AlienwareAndy
    AlienwareAndy New Member
    7 Dec 2009
    Yeah my money is with the 6300 and a reasonable MATX board :)
