Cooling i5 2500k Temps
Discussion in 'Hardware' started by joco2_uk, 1 May 2012.
  1. joco2_uk
    joco2_uk What's a Dremel?
    1 Sep 2009
    Hi,
    I've got a i5 2500k and I think the temperatures are a little high. They are normally around 50-60c sometimes a little higher when just browsing the Internet and doing generally tasks.
    The CPU is water cooled with a Thermaltake Big Water 760IS. I've got a Gigabyte GA-z68X-UD5B3 if that helps as well.
    Can anyone tell me if these temperatures are normal or a bit high?
    Any help or advice would be greatly appreciated.
    John
  2. longweight
    7 May 2011
    What is displaying these temps? What are the temps in the BIOS?
  3. joco2_uk
    1 Sep 2009
    Its a gadget I've got installed but I've also checked in the Bios and the readings are the same.
  4. Bede
    Bede Minimodder
    30 Sep 2007
    Those temps are way too high for casual use. Mine go that high when I stress test, and I'm air cooling. What thermal paste did you use?
    Just in case your gadget is borked, download CPUID's Hardware Monitor and double check what that reports as that is one of the more reliable tools.
  5. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    download coretemp. if its the same then reseat the cpu
  6. joco2_uk
    1 Sep 2009
    Will give it a go. Cant remember the paste, but it wasnt cheap anyway.
    What should the temps be with water cooling?
  7. longweight
    7 May 2011
    Low 20's really at idle and around 40 at load with proper watercooling.
  8. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Your talking best part of £150 for a good watercooling setup too.
    RAD
    Hose
    Fittings
    CPU Block
    Pump/Res
    Fans
