CPU i7 @ 1.6GHZ?
Discussion in 'Hardware' started by Higson92, 20 Aug 2009.
  1. Higson92
    Higson92 What's a Dremel?
    13 Aug 2009
    iNCLUDED PICS. hope they will show. If not its my i7. 920 going down to 1.8ghz or even 1.6ghz at times. Then back up again ? I also disabled side stepping and this made no diffrence ?
    Do you guys like side stepping on or off ?
  2. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    What mobo you using?
    In any case, disable ALL power-saving features and manually set the multiplier to 20 if you want it full pelt constantly. However, remember the multiplier only drops if:
    1) The machine's idling
    2) The CPU is throttling (ie beyond 135W)
    Try running Prime95, and see if it drops during that.
    It shouldn't.
    BTW, why would you want to disable the power-saving features that only work when the machine's idle?
  3. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Side stepping? :lol:
    It's due to Speedstep. It's normal, don't worry about it.
  4. Higson92
    13 Aug 2009
    So do i just change the multiplier to exactly 20 ? or 20.00 do i need to change any voltages or anything or jsut the multi ?
  5. Higson92
    13 Aug 2009
    I disabled and enabled made no diffrence.
  6. Guest-16
    Guest-16 Guest
  7. Higson92
    13 Aug 2009
    i also have a motherboard error. it tells me the cpu is running at 82 c. when it should be around the 50s yet cpu temp apps say my cores around 63 ? i know this is a common error in pv2 mobos.
  8. GoodBytes
    20 Jan 2007
    You know you could have cut the picture so that it only shows CPU-Z.
    - Thanks.
    I don't have a Core i7, but my vote is with the idle.
    Make sure Windows is set to High-Performance as power option.
  9. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    That's still a realy high temp for running at stock and the cpu not in heavy use.
  10. MaverickWill
    26 Apr 2009
    Well, as far as I'm aware (Asus man here), it'll work either way (though for the Asus, 20 changes to 20.0 when you hit enter) - should be an option in the "Manual" settings. Questions to ask:
    1) What motherboard?
    2) Is your cooler seated properly? As far as I know, power-saving features brings on a straight x12 multiplier, unless the processor's being throttled from excess heat, which would be EIST's job (ie throttling above 135W, or specific temperatures). Unlikely at idle, but just a thought.
    3) Have you tried running Prime95, or similar, to make sure the chip runs at the x20 multiplier when it's not idling?
  11. Higson92
    13 Aug 2009
    Asus p6t deluxe v2
    running at 125w
  12. PLM728
    PLM728 What's a Dremel?
    19 Aug 2009
    Mine did this when I got it. I disabled CE1 and speedstep. Set the multi to 20 and that solved it.
  13. MaverickWill
    26 Apr 2009
    Settings on the P6T Deluxe BIOS if you want a permanent 2.66GHz:
    AI Tweaker page:
    AI Tweaker (whatever it's called - the first setting) - Manual
    BCLK - 133
    CPU Ratio - 20.0
    C1E Support - Disabled
    EIST - Disabled
    CPU Spread Spectrum - Disabled
    Sppedstep (tm) Tech - Disabled
    Should all be on there. If not, head straight to the Advanced tab, and check for CPU Configuration.
    Also, check your temps in Hardware Monitor in the BIOS, just to check the mobo's reporting them OK. If they're that high, check your cooler's mounted properly.
    Also, the button next to the "Quote" button is the multi-quote button. Click it on every post you want to quote in a thread, and then click any of the "Quote" buttons. It'll stop you double-posting.
    EDIT - This one ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~\/
  14. Higson92
    13 Aug 2009
  15. MaverickWill
    26 Apr 2009
    Cut from the convo. Just noticed temps hitting a max of 100 degrees. The chip's throttling.
    OP, update your BIOS and re-mount your cooler, just in case.
  16. Higson92
    13 Aug 2009
    no new updates avalible. P.s just touchedd the heat sink and its cool ? if it was really thease temps wouldnt it be very hot ?
  17. MaverickWill
    26 Apr 2009
    Maybe, though the fins will always be reasonably cool. Chances are your board is reporting the temps wrong, and since EIST, etc, goes off these temps, it'll throttle the chip. A BIOS update should fix it. You can do it through the BIOS itself. Just stick the ROM from the download link on a USB stick/CD, and head to the Asus EZ-Update screen in the BIOS (I think it's the one just to the left of the save/discard changes screen). It'll do the update, and hopefully your temps will fly down.
  18. Higson92
    13 Aug 2009
    **** my fan has cut my finger real bad.............. anyhow how can i update when i have the latest update udner the bios ?
  19. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    You cant.
    Have you tried taking the cpu cooler off and putting it back on?
    Also, how much thermal paste did you use on it?
    Pics of that would help greatly.
  20. MaverickWill
    26 Apr 2009
    You can downgrade to an earlier BIOS with the ASUS boards. Try the one before the latest BIOS.
    Also, silly Higson for trying to stop a fan with your finger!
