CPU i7 3820 as next upgrade
Discussion in 'Hardware' started by Andre_B, 2 Feb 2012.
  1. Pookeyhead
    30 Jan 2004
    If you're gaming, and not doing any CPU intensive tasks, then I'd wait a little while and go Ivy Bridge. Isn't there a new chipset arriving with that? That's probably what I would do.
    If you desperately need to upgrade now, then just go 1155 and stick a OCed 2700K in there.
    There's no advantage to games by going SB-E.
  2. law99
    law99 Custom User Title
    24 Sep 2009
    it costs £70 or less to have 16gb of ram in 4 dims. I don't think upgrading to a 2700k is going to be a bad shout when it comes to lasting a while. Let alone when the sandybridge-e comes.
    I highly doubt you'll need to have more for your VMs. Considering at work, a lot of people still need to run XP as a VM within 7 because of old proprietary software on a lowly 4gb and dual cores i5 laptops and don't complain about it, you'll be ok for your studies.
    In fact, the IT guy at work, after I showed him the speed of SSDs, went right ahead and started using his laptop to run a couple of VMs, either for building and testing before firing over to a co-lo or just for fun. All on 8gb and a i7 2ghz (pre sandybridge) whilst needing 7 and XP running at the same time.
    I think people overestimate what they need to make do sometimes... not that I blame them; just if you want the best stuff, come out and say it. In which case, just buy the Ivybridge 3960x and be done with it.
  3. Andre_B
    Andre_B Minimodder
    17 May 2009
    If you run server software like Windows 2008 with exchange etc, it will easily eat up RAM. I'm planning on running a couple of servers so that I can experiment between them and a couple of hosts. I had a quick look on Scan and they have a 24GB kit for £116 which might be an alternative option, but I'm worried that I might be throwing money on a dead socket/platform.
    Sent from Bittech Android app
  4. JohnSheridan
    JohnSheridan What's a Dremel?
    30 Dec 2010
    Socket 2011 will be with us longer than socket 1155.
    IB-E is not due out until Q4 2012 and that will be a drop in on socket 2011
  5. law99
    24 Sep 2009
    Well, that's basically what they've been doing at work. Building exchange servers for different regions, firing them over to co-lo's in a migration that's happening. Because its global, it has to be a live environment. There is various other servers being made also. I got to go in the data centre the other day, it was pretty geeky but cool to :)
  6. Andre_B
    Andre_B Minimodder
    17 May 2009
    It sounds like a really interesting job.
    If I'm running more than one server and a couple of hosts for lab purposes, I'm worried about running out of memory. As much as I like the idea of LGA 1155 being cheaper overall etc, it doesn't give me any flexibility in the RAM department.
