Build Advice I7-4790K -> Equivalent Ryzen?
Discussion in 'Hardware' started by Impatience, 6 Jun 2019.
  1. Impatience
    Impatience Minimodder
    6 Apr 2014
    Hi all, motherboard has died on my Haswell rig, by the looks of it.. :( Looking at taking the plunge and going for a Ryzen upgrade, but don’t have a shedload of money to throw at the upgrade!
    Used for 1080p gaming and some video/photo editing, currently on 16GB DDR3 and a SATA SSD.. I’m not wanting to LOSE performance, So im wondering what the equivalent Ryzen chip to my current CPU would be.?
  2. faugusztin
    11 Aug 2008
    Did you mean 4790K with or without overclock ? At stock, Ryzen 5 2400G would come close, but lose a bit. Ryzen 5 2600 would beat 4790K.
    If you overclocked the 4790K, then that might bring it close to stock Ryzen 5 2600.
    On other side, Ryzen 5 3600 launches on July 7, which should give you another 10-15% extra performance; but then Ryzen 5 2600 is pretty cheap right now, Amazon has it for 130 GBP for example.
  3. Impatience
    6 Apr 2014
    Wow, ok. Didn’t realise that the mid-range chips had come along that much in comparison to my i7! Definitely seems like I’ll be making the switch to one of the two if I can’t source a decently priced motherboard/work out what the issue is..
  4. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Here's some side-by-side comparisons of the passmork score on these chips.
    2400G - slightly slower on passmark, 2600 slightly faster on passmark.
    https://www.cpubenchmark.net/compar...i7-4790K-vs-AMD-Ryzen-5-2600/3183vs2275vs3243
    Your secondhand price for a 4790K is going to be £80-£100.
    CEX will buy your 4790K for £106 voucher or £75 cash - and interestingly enough, in fact sell a Ryzen 5 2400G for £105 - so if that helps, you could 1:1 swap your CPU. They also sell the Ryzen 5 2600 for £130 if you wanted to top it up by £24 - which when you put it that way sounds like a bit of a no-brainer.
    If you aim for a x570 motherboard, allowing you to put a 3000 chip in later for the full PCI-E4.0 boost if you do need more speed, then you just need to sort your RAM out. A matched set of 16GB should be £50 or so inc maybe a bit less, which will go a long way towards your DDR4 purchase.
    Might make the initial jump that bit cheaper/easier?
  5. Arboreal
    21 Jan 2011
    Interesting to hear all this, as my i5 4670K seems to be fine, but I'm looking to move to something newer.
    If you buy a Ryzen 'G' CPU, I think the PCIe lanes to an external GPU are limited compared to a mainstream Ryzen. That said, PCIe 8x vs 16x shows minimal loss in most normal and gaming situations.
    R5 2600 or thereabouts as a hex core look quite tempting.
  6. Vault-Tec
    30 Aug 2015
    This new Ryzen 3600 is faster than the existing 2700x.
    I've also seen hints that it's not so reliant on memory speed either, meaning I may just pop for a 12 core myself. I still don't want to change my RAM. That is what has kept me happily chugging by on Intel tbh.
  7. Hardware_Numb3rs
    Hardware_Numb3rs What's a Dremel?
    21 Apr 2019
    The 3600/3600X seems a great chip for a value upgrade, but memories are important, and a good kit should be taken in consideration, if not B-Die the Hynix CJR like the Gskill SniperX 3600 is a nice alternative, or for a more budget one a Hyperx Fury 3200 C18 1.2V can be fine (for the price).
    Regarding the motherboard, if you go for a budget upgrade probably a B450 will do fine for a 3600/3600X and you can save a lot.
    As always, the better thing to do now is to wait the launch and see the reviews and benchmarks :)
