CPU i7 930 temps advice please.
Discussion in 'Hardware' started by angel_dust, 14 Aug 2010.
  1. angel_dust
    angel_dust What's a Dremel?
    13 Apr 2008
    Hi all
    I finally got my system up and running for just now. I noticed last night that CPU temps had went from around 35C at idle to 60C after a hour of Prime95, with a room temp of 22C.
    That seems high to me for a i7 930 that's not been overclocked yet with a Magahalems stuck on top. I still have everything set to auto in BIOS. I've not had time to mess about with them yet so voltages maybe a little higher than normal.
    i7 930, Megahalems cooler, Rampage 3 Extreme, 6gb Corsair Dominator, GTX 285,
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    That does seem high, should be more in the high 40's. The first 2 things to look at are the heatsink fitting and thermal paste. You may have mismounted it. You also may have applied too little/ too much thermal paste.
    bulldogjeff likes this.
  3. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Those temps are actually fine, considering that Prime95 and other benmarking programs push your processor harder than it will ever go in day-to-day usage. Nothing to worry about :)
  4. Teelzebub
    27 Nov 2009
    Yeah they dont seem that bad really.
  5. angel_dust
    13 Apr 2008
    I used Artic Silver 5, and reseated the cooler about 3 times untill I thought I had the right amount on.
    But I never trust myself.;)
  6. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    Those temperatures aren't at all dangerous - the 930 will automatically shut off up around the 100+ degree mark and 85ish degrees at load would be fine. I would start over clocking and just keep a good eye on it.
    Aside from the thermal paste and fit of the cooler, you need to make sure that you have good airflow through your case. What is your case, fan & fan direction setup?
  7. SmilerAl
    SmilerAl Terminate with extreme prejudice
    6 May 2010
    Hook it up with a Cosair H50, mine never gets over 40 on anything I'm doing.
  8. angel_dust
    13 Apr 2008
    The case is an aging Silverstone TJ09 and I've one PWM Akasa Viper fan stuck on the cooler, which only sins about 6-700rpm at idle.
  9. GoodBytes
    20 Jan 2007
    Can I see your case air flow, by posting a picture of your case open?
  10. roosauce
    12 Feb 2010
    What about intake and outtake fans?
  11. Bugste81
    Bugste81 Stephen
    16 Mar 2010
    Just Bought a 930 too. Is there any danger of overheating with the stock cooler or is it up to scratch if no overclocking is involved?
  12. GoodBytes
    20 Jan 2007
    Of course not. The Intel heatsink (same applies for ALL processors) has been designed to sustain the CPU under hard condition (assuming your not overclocking).
    Potential problem that could lead to bad cooling are:
    - Miss installed heatsink.
    - Bad air flow due to obstacles in the case such as wires.
    - Bad air flow of the case design.
    - Manufacture error on the thermal paste/pad.
  13. angel_dust
    13 Apr 2008
    I did a basic overclock last night to see how high the temps would go.
    With a overclock of 3.8GHz a Vcore of 1.24 and CPU PLL of 1.90, the core temps went up to 0-76c, 1-75c, 2-73c, 3-74c after Prime95 running for 45 mins. Core 0 always seemed to run higher than the rest. The idle temps were about 43c. ( I didn't have time to let Prime run longer ).
    They still seem on the high side to me.
  14. adam_bagpuss
    24 Apr 2009
    seems fine to me.
    mine idles at 35-40C and under load its around 65-75C all depending on my room temp of course.
    Edit - i have a corasir H50
  15. roosauce
    12 Feb 2010
    Also sounds pretty fine to me. My 3.8 GHz 920 hits around the ~75+ degree mark at full 8-thread load.
  16. *brian*
    *brian* What's a Dremel?
    23 Jul 2010
    Unless you're a folder :D
    But yeah, the temps are fine.
  17. rollo
    rollo Modder
    16 May 2008
    make sure voltages are set collectly and you will gain a few c less
    35 idle
    50-60 under load is nothing to worry about
    70-80 at 4ghz is a normal temp under load if you leave speed steping enabled you can get it to drop alot when not been used though
  18. Ady6UK
    Ady6UK Feck Off
    24 Apr 2009
    Your temps seem fairly normal at 3.8 GHZ so I wouldn't worry too much.
    I use one of these:
    Its a Cogage Arrow. Its a big beastie but does a first class job of cooling. I fitted two Akasa 120mm fans to it and they run at 1100rpm off a Scythe fan controller. The temps are good as well after running prime95 (with Hyperthreading on):
  19. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    I think its more to do with using only 1.24v for 4GHz. Most people need 1.3v+ and thats when their temperature rise above 70c.
  20. Ady6UK
    Ady6UK Feck Off
    24 Apr 2009
    I did have it at 1.3v initially but kept bringing the voltage down till it became unstable and then brought it up a fraction. Even at 1.3v it was only a few degrees warmer (the hottest core was high 60's celcius).
    But getting back on track, as I said angel_dust your temps seem o.k.
