Overclocking i7 930 with an ASUS P6T, titan fenrir
Discussion in 'Hardware' started by onthejazz, 12 Mar 2010.
  1. onthejazz
    onthejazz What's a Dremel?
    17 Feb 2010
    Hi,
    I've never overclocked a PC before and I'm worried about damaging my new hardware. Am I right in thinking that I can just copy the settings laid out in the thread for the i7 920 straight into my BIOS? Are there any other features I need to turn on or off or do I need to move any motherboard pins around?
  2. saspro
    saspro IT monkey
    23 Apr 2009
    You can more or less use the settings as a guide, don't jump straight in with the settings listed.
    Also remember the 930 runs at a different stock speed so you'll need to make the relevent changes (usually multipliers)
  3. onthejazz
    17 Feb 2010
    To me 4Ghz (from the guide) sounds high, would it be possible to overclock to say 3.5Ghz using the multipliers?
  4. saspro
    saspro IT monkey
    23 Apr 2009
    175 blk with a 20 multiplier would do it. Turn of fturbo boost to stop it from jumping up under load.
    Just set your RAM at the right speed & voltage, the board will do most of the rest (although you should really set the voltages yourself for a really stable, cooler OC)
  5. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    Baseclock of 175 and the multiplier set to 20 and you have 3.5. Only those two settings need to be changed, so no overvolting is required.
  6. rollo
    rollo Modder
    16 May 2008
    Chip is fast enough at base I'd suggest not overclocking in your case
  7. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    3.6GHz is a nice OC, 180X20 leave turbo on and don't touch the voltages...
    Thats what I did and I set my RAM to 1800MHz...
  8. saspro
    saspro IT monkey
    23 Apr 2009
    Fast is never fast enough. Both my 920's are running at 4GHz (5 min OC) and I still want more speed.
  9. cybergenics
    cybergenics What's a Dremel?
    27 Jun 2009
    To the OP, update your BIOS before you begin, in my first 920 system, the particular BIOS (Asus P6T SE) it shipped with was stable at 188 and blue screened at 189 even with more volts. The one I updated to had no such issue.
  10. rollo
    rollo Modder
    16 May 2008
    hes a noob overclocker saspro. People who have no idea what they are doing should leave overclocking alone. Start small 3ghz then 3.1 3.2 ect
    stop around 3.5ghz and be happy
  11. Guest-16
    Guest-16 Guest
    Buy an SSD :p
  12. onthejazz
    17 Feb 2010
    Before overclocking I installed CPU-Z and I think I'm getting some strange readings?
    Core voltage: between 0.944 and 1.2V
    Core speed: 1603 MHz
    Multiplier: 12
    bus speed: 133.6 MHz
    QPI Link: 2405.5
    However, sometimes the multiplier will jump to 21? Is this normal?
    My non stressed cpu temperature is 34C.
  13. Teelzebub
    27 Nov 2009
    That's speedstep working it lowers the speed when in idle , download prime 95 and stress test it .
  14. onthejazz
    17 Feb 2010
    ok, I downloaded 'Prime95' and my new CPU-Z readings are
    core speed 2939
    multiplier 22
    bus speed 133.6 MHz
    QPI link: 2405.5
    The CPU temperature appears to have remained constant
  15. GingerFox
    GingerFox What's a Dremel?
    15 Nov 2009
    How would anyone ever learn?
    For example i had never overlcocked before and now my q6600 is running at 3.8ghz stable.
  16. memeroot
    memeroot aged and experianced
    31 Oct 2009
    take it up there in stages, if its stable its good, if it's unstable bring it down again... simple
    if you cant afford to replace hardware dont increase voltage
    but dont worry overly - bit tec got 3,8 stable
    btw - given a 750 goes faster then why go 930 if you dont clock it fast?
  17. memeroot
    31 Oct 2009
  18. memeroot
    31 Oct 2009
  19. onthejazz
    17 Feb 2010
    I wanted hyper-threading for video editing
