Overclocking i7 overclocking
Discussion in 'Hardware' started by kenco_uk, 16 Jul 2009.
  1. kenco_uk
    28 Nov 2003
    Mine goes red at 1.90.
  2. Slaymate
    Slaymate bit-tech Slayer
    15 Feb 2009
    I had it set at 1.625 volts in the bios. It handled that fine. The next day when I pushed my CPU VTT (QPI volts) up to 1.575 trying to hit 5GHz it fried the voltage regulator circuitry. I have a Classified coming in now :D
    In my spare time at work today I lapped my cpu :D
  3. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    That is some seriously nice lapping. When I grow a pair (and I'm 40) I might try lapping my cpu. Wasn't too bothered about lapping the cpu waterblock, if that went wrong I could always get another before rebuilding.
    If I screwed up the CPU I'd be looking at a holiday in the garden instead of abroad. Don't think the wife would be too happy.
    Anyway, looking forward to seeing the results you get from the Classified, from all accounts it's a beast of a board. Not jealous at all ;)
    When you do get the classified up and running, I'd love to see what score you can get on the Custom PC benchmark: Link
    At the moment I'm holding on to 15th place. I just can't seem to get my multitasking score to a reasonable level. Still, I am above a couple of the Benchtec people using LN2 on Core 2's.
  4. ChArMz
    ChArMz What's a Dremel?
    19 Jul 2007
    im afraid i may break my brand new i7 920, this OCin is way to scary for me, i would have to have someone here with me
  5. Pookeyhead
    30 Jan 2004
  6. Chris_Waddle
    26 Mar 2009
    Thanks for the link Pookey. I'll give it a good read.
    I have lapped my cpu blocks etc, It's a situation a bit like ChArMz is with overclocking. He doesn't want to damage his CPU bu overclocking it; which I have no worries about doing and I don't fancy lapping my CPU yet for the same reasons.
    I think I'll wait until my wifes old Athlon finally gives up the ghost and practice on that first.
  7. SwiftDestiny101
    SwiftDestiny101 Has a wire neatness fetish...
    23 Apr 2009
    Seens as everyone here helped me so much I figured I'd post my final stable OC.
    Motherboard: Asus P6T Deluxe V2
    CPU: i7 920
    Cooling Used: Titan Fenrir + MX-2
    Overclocked Speed: 3.8 GHz
    UnCore Speed (UCLK): 3.6 GHz
    Baseclock (BCLK): 200 MHz
    DRAM Speed: 1600 @ 8-8-8-24 1T
    Turbo Mode: Off
    Hyper-Threading: On
    HPET: On
    Speedstep: On
    Loadline Calibration: On
    CPU Voltage: 1.21250 V
    CPU PLL Voltage: 1.80 V
    QPI/DRam Voltage: 1.35 V
    DRam Voltage: 1.66 V
    IOH Voltage: 1.20 V
    ICH Voltage: 1.30 V
  8. Pookeyhead
    30 Jan 2004
    Looks a nice, 24/7 OC :) How long have you stressed it for?
  9. SwiftDestiny101
    23 Apr 2009
    Prime till I got bored, and 50 iterations of LinX :)
    And I owe it all to you :blush:
  10. Eddieboi
    Eddieboi What's a Dremel?
    27 Jun 2009
    Just a slight question I have the standard P6T motherboard, is that any good for overlocking? Also I have XMS3 1333 memory
  11. nikeunltd
    nikeunltd Epic destruction around machinary
    5 Apr 2008
    what programs are you guys overclocking ur comps with??? because i thought Bios is the best, but its soo annoying restarting over and over again...
  12. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Bios.
  13. SwiftDestiny101
    23 Apr 2009
    BIOS, yes it's time consuming but you can get a much more stable overclock at the end of it.
    Just put 2 nights aside to get it done, and read a book while it LinX's for half hour between changing settings :)
  14. Pookeyhead
    30 Jan 2004
    LOL
    Just glad it helped someone :)
    BIOS all the way. As Swift said.. it's very annoying, yes, but almost all windows application for overclocking are useless. In fact that the Turbo V application that comes with the P6T is so flakey it used to crash if I so much as changed anything once I was past 3.5GHz.
    Annoying as it is... you really need to be using the BIOS.
  15. kenco_uk
    28 Nov 2003
    To save a lot of time waiting for an OS to boot up, temporarily bung a spare drive or make a partition with a bare Vista/XP/7/whatever on as it'll take far less time to reboot from bios. It'll only take half an hour to install, if that, but saves so much time waiting.
  16. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I agree with that^.
    Install some small fast-booting OS on a temporary drive as your overclocking OS, and put the most important OC'ing tools on the desktop or even in the startup folder.
  17. earlydoors
    earlydoors Minimodder
    12 May 2009
    Okay, so I'm looking for a nice simple 3Ghz OC for 24/7 usage :)
    This is me:
    Core i7 920 D0
    Gigabyte GA-EX58-UD4
    6GB OCZ 1333Mhz RAM
    So, I've downloaded various benchmarking tools, plus realtemp. I've Prime95'ed my stock setup to check temps and ensure it's stable and I'm happy
    Temps are okay, 33-35 idle and 70-73 load. I have a Fenrir with AS-5
    My graphics card came with a free copy of 3Dmark Vantage and I've benchmarked it.
    Now in terms of overclocking...can I raise my Bclk bit by bit to 150, while leaving everything else on Auto and tweaking nothing else? Or if not, what else do I have to tweak and when!?
    Cheers!
  18. Slizza
    23 Apr 2009
    Yes you can.
    Just remember and set the ram speed aswell.
  19. earlydoors
    12 May 2009
    Thanks for this - how do i figure out what speed to set my RAM at?
    I am nub. :idea:
  20. Slizza
    23 Apr 2009
    The speeds will be in a drop down list.
    Just select the option closest to 1333.
    Like this
