Build Advice i7 rig
Discussion in 'Hardware' started by bobtheangryflower, 30 Apr 2009.
  1. bobtheangryflower
    bobtheangryflower lalala
    29 Oct 2007
    heres the specs
    core i7 920
    asus p6t
    6gb mushkin ddr3 1066mhz ram
    500gb western digital caviar green
    evga gtx 260 superclocked
    and case with 500 w powersupply
    if i want to overclock to 4ghz would i need to get a better power supply
    if so what wattage should i use
  2. ry@n
    ry@n Minimodder
    31 Aug 2005
    What PSU do you have for a start?
  3. bobtheangryflower
    29 Oct 2007
    im not sure what brand it comes with the case its 500 w
  4. ry@n
    ry@n Minimodder
    31 Aug 2005
    You shouldn't be risking your nice i7 setup with an unbranded 500w PSU that came with your case, thats unless your case is a Coolermaster for example which supply decent PSUs with their cases.
  5. bobtheangryflower
    29 Oct 2007
  6. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I wouldn't touch that PSU either TBH.
    Get a 600W+ Corsair, Enermax, Seasonic or PC Power&Cooling unit. Brand really does matter when it comes to PSUs, you don't want a cheap nasty power supply taking out all of your nice expensive hardware.
    This Enermax unit, or this Corsair unit would be excellent choices.
  7. bobtheangryflower
    29 Oct 2007
    i guess ill go ahead and get a corsair 750w to be safe
  8. ry@n
    ry@n Minimodder
    31 Aug 2005
    Good choice :)
  9. Guest-16
    Guest-16 Guest
    Why the WD Green hard drive? It saves very little power but it's notably slower? They're only good for always-on storage applications because they are extremely quiet and don't get at all hot.
  10. adam_bagpuss
    24 Apr 2009
    +1 on the HDD the green series are rubbish dont even save that much power.
    get the WD blue series 640GB its much faster
  11. Danny24
    Danny24 What's a Dremel?
    30 Apr 2009
    Hi why not jus get a 1TB HDD Much better and round same pric :=p
  12. adam_bagpuss
    24 Apr 2009
    its not the same price really
    £54 for the WD 640GB
    £70 for the 1TB samsung ( i use this one as alot of 1TB are crap especially the old ones)
    22-23% more expensive really
  13. Pookeyhead
    30 Jan 2004
    Thats one way of looking at it... my way of looking at it would be it's only £16 more for a much faster, and larger drive.
    Money well spent.
    Get the 1Tb Spinpoint F1. I have 2 of them.. great drives. Quiet, fast, cool.
  14. adam_bagpuss
    24 Apr 2009
    thing is its not much faster.
    i have a F1 samsung also its a great drive but the WD 640GB blue series is also very quick.
    The F1 is faster but the WD is not much slower. i suppose £16 isnt alot but if your working to a budget then stick to it. There is always something faster for that little bit more money.
    Some of the 1.5TB HDD are faster than the F1 now as they have 500GB areal densities compared with the 333-4GB for the 1TB F1.
    suppose at end of the day if you have an extra £16 to get it no reason not to if you need to stick to a budget then the WD640GB is still a very good drive
  15. Pookeyhead
    30 Jan 2004
    £16 for a drive that is faster... regardless of how much, and let's not forget that we're talking about 640Gb vs. 1TB as well, so there's a size issue.
    Just seems odd that when speccing a high end rig like a i7, £16 becomes an issue.
  16. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    WD Green is slow, WD Blue (and Black aswell) is fast.
  17. Guest-16
    Guest-16 Guest
    Your hard drive is a greatest bottleneck to any system. Getting even a bit faster make that much edge of difference.
    A journo friend of mine who writes for TR has an "old" dual core PC by our standards but blagged an X25-M off Intel. He can load a dozen firefox windows in 2 seconds and multiple office apps in under 5s. The balance between throughput and random read/write speed makes the diff.
