News IBM heats university via supercomputer
Discussion in 'Article Discussion' started by CardJoe, 25 Jun 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    how do they get the water to 60C in the first place to introduce into the system? haha
    ...someone put the kettle on...
  3. PT88
    PT88 What's a Dremel?
    13 Apr 2009
    if i understand correctly the water is part of the Universitys Heating system, so the water in the heating loop will probably be 60 degrees. I guess its jus a matter of taking some "used" water from the system to cool the Rig, ie water that has already been thru radiators
    Good idea
  4. Krikkit
    21 Jan 2003
    The two loops are separate. No water is taken from the heating through the computer.
    The rack itself will heat the water to 60'C without too much trouble from nothing anyway - just lower the flow of the water. Even if they did use a kettle, don't forget you'll only have to heat the water to 60'C once too - it doesn't go off every night like normal computers.
    Clever idea really - in summer when the heating's off they can just keep exchanging the heat with the giant heating system anyway, so no worries about overheating!
  5. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    If anything, I'm more surprised that this hasn't been done before.
  6. mclean007
    mclean007 Officious Bystander
    22 May 2003
    I read not too long ago about a plan to exhaust server room heat into large greenhouses. This is not dissimilar. Makes perfect sense to me. There was also that other plan involving an offshore tidal generator off the north of Scotland, the difficulty being the cost and inefficiency of moving the power generated hundreds of miles to civilisation. The genius plan was to build a server farm up there to soak up the majority of the power, use the waste heat to warm greenhouses, connect to the local grid to feed in spare power or receive top-up power where needed, and just have a bundle of fibre-optics going up there rather than dirty great UHV power lines. Smart thinking I say.
  7. robyholmes
    robyholmes I'm under your desk...
    17 Jan 2008
    I have seen someone heat a swimming pool online with 4 computers? Or help too heat it.
  8. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Google have been pioneering things like this for a while now, basically people realised that you dont need to keep data centers at -20 degrees - I believe Googles' most nerdy datacenter uses an evaporation tower to get rid of excess joules...
  9. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    Google also did a test about HDD's, where the cold, warm, and hot disks were tallied from the dead disks.
    They found that more disks went funny if they were kept cold and/or hot, but the longest life was warm.
    Or so I remember.
    Basically, you didn't need to keep the disks cold was the output.
    I find 60C a bit high for a starting point, but they will have tested it to death, and a security will be in place so nothing will fry.
    A very good idea.
  10. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    60c is perfectly within the operating range of modern processors. They're not trying to overclock them, after all, so there's no real need to cool, just to keep the chips from overheating.
  11. I-E-D
    I-E-D Minimodder
    28 May 2009
    Exactly my though son :)
    So how many normal computers would I need to watercool them all providing enough heat to all the radiators in my house?
    :D make one massive loop. 5 i7 OC'd i7 Computers, attached to 1000mm radiators, and a huge waterpump. Sorted :) Well, bye bye heating bills, hello electricty :S
  12. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    I've been considering using my loop for underfloor heating! although leak detection would mean pulling the floor up!
  13. Goty
    Goty Minimodder
    13 Dec 2005
    The water is 60C, not the processors. You've got to keep in mind the CPU-water temp delta. Granted, assuming their system doesn't royally suck, their delta shouldn't be anywhere near high enough to matter.
    As for the system itself, 10 TFLOPS seems kind of... low...
    Seriously, there are plenty of enthusiasts out there that approach half this computing power on video cards alone.
  14. kempez
    kempez modding again!
    4 Aug 2005
    That's pretty cool (;))
    Our data centre is used to heat the building too :)
  15. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    This suggests itself as a combined technology with that remote game playing thing, where the game runs remotely and sends you the result as a video image. Scale that up a few orders of magnitude, and you've got a civic computer cluster that serves a whole town, and provides heat to it as well.
    Of course we'll all be living in arcologies by the time that happens...
    P
  16. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Like an extension of combined heat and power: combined heat power and computing :)
  17. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    my computer has been heating my room for years! It was the only thing to keep me warm at night in uni halls, had it running intels burn test to keep it at 100% load over night.
  18. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    I read another article about the same setup where the water temp was 40°C.
    Nice initiative though.
  19. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    very cool but I doubt it's a new idea
    In the colder day around here I'll leave my computer on (running a 75% with Fold@home) to keep warm
  20. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    see i said i should have patented my idea, lol
Tags: Add Tags
