Case Mod - In Progress IBM PS/1 2125-RoG - 06 June 2015
Discussion in 'Project Logs' started by IBMer, 6 Jun 2015.
  1. IBMer
    IBMer Minimodder
    5 Jun 2015
    Hi everyone.
    I have had a few attempts at making my own cases in acrylic for some time but there was nothing worth sharing compared to the amazing mods and scratchbuilds I see here. Lately however I got the idea of modding one of the dinosaurs buried in my basement, as I was thinking about building a more compact case than the Lian-Li PC 27 I used.
    It is still done with (very) limited skills, tools, budget and time, mostly using spare parts and materials.
    Above all it is a tribute to my first ever PC, an IBM PS/1 model 2011, first model of the PS/1 series, which was launched exactly 25 years ago in June 1990.
    So let me introduce to you the project:
    IBM PS/1 2125-RoG
    The host case:
    27cm (length) x 35cm (depth) x11cm (height), I don’t have the monitor.
    I did not use my original PS/1 Model 2011 (a 286@10MHz, with 1MB RAM and 30MB HDD) as it is in working condition and at the time it felt really too small. I thus used an IBM PS/1 Model 2121 of 1992, originally a 386sx16, which is basically as big as two 2011 stacked. Since then I found a second spare 2011 case and started thinking about a new project.
    The nice thing about early PS/1 cases is the way they slide open: front/top/sides upper cover slides on the bottom/back plate, leaving all the internals easily accessible. There are no screws, just a single button on top, locking the upper cover in place.
    Objectives:
    Give a more modern look to the case while…
    … Preserving the original shape a maximum, especially the way it slides open
    … Fitting-in the following gears:
    • Intel i5 4670k cooled with a Antec Kühler 620
    • Asus ROG Impact VI with 2x8GB of G.Skill DDR3-2400 Trident X
    • EVGA Geforce GTX 770 SC 2GB cooled with a Corsair H55 mounted with a Kraken G10
    • Crucial MX500 M.2 500GB SSD & WD Caviar Blue 1TB 3.5’’ HDD
    … Getting decent cooling by keeping the two closed-circuit loops.
    … Avoiding the use of a PCI-E riser (no space for a rigid one and I never managed to get a decent flexible one)… this meant adding a minimum of 2cm to the original height…
    A glance at the final result:
    Step 1 : the bottom plate/motherboard tray and the back-plate
    I had a first try at making a whole new bottom plate in acrylic, but the end result was bulky and the sliding/locking was not as good as the original.
    I thus chose a lighter design, cutting the bottom plate just where it was needed to fit the mother-board and graphic card, and getting the additional 2cm required by using a spare 4mm acrylic sheet and 2cm L-shaped aluminium rails.
    The original bottom plate, cut:
    Work done on the new motherboard tray:
    This design improved the cooling system I thought about (by providing more clearance under the case): stacking the two radiators and two Be Quiet 120mm fans, with air taken from underneath the case, exhausted on top.
    On the left side rail I drilled a holes to fit USB and audio ports taken from a Bitfenix case and also a rectangular hole to exhaust a bit of the GPU's RAM/VRM warm air. In addition I cut a round hole on the tiny front rail to host on/off button from a Lian-li case.
    I used the same spare acrylic for the back-plate, painted in the same flashy red as the MB tray for the inside and covered with a fake carbon fibre sticker for the outside.
    Work done on the backplate:
    The final look of the bottom/back plate:
    Step 2: work on the cover
    A simple paint job on the front plate:
    Some trials and errors on the upper part of the case, gladly invisible now.
    Initially I had thought to cut a hole for a 120mm fan grill, but the end result was quite uggly.
    I then found 16.5cm speaker cover from a VW Gold 4, which used as a fan grill would have the advantage to hide my deplorable lack of skill at drilling/cutting.
    Work on the case was completed but I was still a bit worried about how everything would fit in there.
    Step 3: Fitting everything in.
    Cable management was as expected a real issue :)
    Here is a look at the inside, with all parts and wires in, except for the SFX PSU which comes above the CPU.
    Here is a side view when closed.
    A view at the not too great back plate :sigh:
    And finally a look at the working PC.
    The background pic is the original welcome screen of the PS/1, a simple shell for PC-DOS 4.01. I also installed another classic piece of IBM memorabilia for the picture: an IBM RT3200 including a trackpoint, ThinkPad style.
    The whole thing has a Thinkpad/Intellistation feel actually.
    What’s next?
    • I realized I forgot to put a HDD LED, I will install it on the A: LED space on the front.
    • I may make a better back plate.
    • Think about a custom water cooling.
    • I have the project of putting the same gears in the original PS/1 2011 case (half the heigth of this one) with a custom WC with pump/tank/rad in a small tower outside.
    List of the gears used in this built:
    • Intel i5 4670k@4200Mhz, cooled by an Antec Kühler 620
    • Asus ROG Impact VI motherboard
    • 2x8GB DDR3-2400 G-Skill Trident X
    • EVGA Geforce GTX 770 SC 2GB cooled with a Corsair H55 mounted with a Kraken G10, mildly overclocked to 1161/1213MHz for GPU and 1788MHz for memory.
    • SilverStone SX600-G SFX 600W PSU
    • Lian-Li PT-SK03B kit for the power button
    • 2x be quiet! Shadow Wings PWM 120 mm Fans
    • 1x Noctua NF-A6X25 FLX fan for the front air intake (through the floppy drive hole). I am thankful to Noctua for coming with this rather unusual form factor
    • BitFenix USB 3.0 Upgrade Kit for Outlaw and Shinobi for USD 3/USB2/Audio front ports
    • A 120mm Silverstone magnetic fan filter, stuck underneath the case.
    • A blue led to replace the original orange one.
  2. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    I see no pictures?
    You need to have in work pictures in your first post.
  3. IBMer
    IBMer Minimodder
    5 Jun 2015
    Thanks for letting me know. Pictures appear on my screen, they're hosted on a Bit Tech album. But there might be an issue on how I posted them.
  4. storm-83
    storm-83 Minimodder
    7 Nov 2014
    dug this one up after seeing your new build
    i really like your projects!
    specific to this build, how are temps with 2 radiators staced?
  5. IBMer
    IBMer Minimodder
    5 Jun 2015
    Hi and thanks for the interest.
    Both GPU and CPU stay below 60° these days with a room temp of about 22°... I'm actually used to much lower temps, hence the idea to go for a custom loop on the new project...
    I could also try to invert both rads and see if I obtain better temperatures.
  6. storm-83
    storm-83 Minimodder
    7 Nov 2014
    i'm not surprised, but it's not as bad as i thought it would be!
    really wish i had gone for an itx mobo when i upgraded last - it opens up for more versatility
  7. IBMer
    IBMer Minimodder
    5 Jun 2015
    Answered a bit fast sorry:
    Temps iddle/low activity: CPU around 35°, GPU: below 30°
    Gaming (I mostly play PlanetSide 2): both CPU and GPU around 55-60°
  8. storm-83
    storm-83 Minimodder
    7 Nov 2014
    wow, those are nice idle temps - thought idle and active temps would have been closer together...
    nice! :D
