Apple Ibook - easy to keep clean?
Discussion in 'Software' started by hellomoto, 6 Apr 2005.
  1. hellomoto
    hellomoto What's a Dremel?
    4 Sep 2003
    I've noticed with many of my friend's ibooks that when leaving your hand next to the mouse pad, after a while it stains the plastic. For example in this picture you can see in the bottom right hand corner.
    Is it just dirty, or the plastic wearing off? My mate has tried to clean his but it made no difference..
    :s
  2. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    It looks like dirt or grime to me. The iBook is painted on the inside of the plastic casing, so the paint isn't wearing off. I'm not sure about the plastic wearing off, I don't see how that would happen.
  3. RTT
    RTT #parp
    12 Mar 2001
    It probably is discoloring as you suggested - my trusty MS natural keyboard is very discolored where my hands rest (5 years old) no matter how much I clean it.
  4. fathazza
    fathazza Freed on Probation
    20 May 2002
    hehe, bet mine is yellower than yours ;)
    and that ibook looks nasty
  5. feckless2k1
    feckless2k1 Minimodder
    2 Sep 2003
    mine is fine after about 6 months, no noticable discolouration. If you keep it in good nick then I think it should be ok for a long time, but of course it is more prone to dirt than other colours.
  6. relix
    relix Minimodder
    14 Nov 2001
    I have one of them black sexy ones, and where my hands rest it's just very shiny and polished :D
  7. nick[x1]
    nick[x1] What's a Dremel?
    1 Nov 2004
    Theres some foam you can get from RS I think, for cleaning creme,white computer casing and all you basicly do is spray it on and scrub it in and it just cleans it :S
    Cant remember the name but its dam good stuff!!!
    Love the ibook :)
  8. ginguskahn
    ginguskahn What's a Dremel?
    22 Apr 2001
    This has happened to all my laptops, and any beige keyboard with a wrist rest, even when i got into the habit of washing my hands before doing anything with the computer. As Nick says there is proper stuff to get this off, as it seems to get into the dimples of the plastic or something and wont come off with a good scrub.
