Case Mod - In Progress Icelandic Winter worklog
Discussion in 'Project Logs' started by AciD_RaiN, 18 Oct 2012.
  1. AciD_RaiN
    AciD_RaiN What's a Dremel?
    29 Jul 2012
    Hi everybody :) I'm just starting a new mod called Icelandic Winter. Iceland is a small island so I thought the Bitfenix Prodigy would be perfect for this mod. Now when the winter is coming, I can't do any painting since I have to do all that outside but we will figure something out ;)
    Hardware:
    CPU: i5 3570k
    MB: ASRock Z77 E-ITX
    RAM: Corsair Vengeance 8GB DDR3-1600 Low Profile White
    SSD: Samsung 840 120GB
    Storage: None internal
    GPU: EVGA GTX 670 Cheesecake
    Case: Bitfenix Prodigy White
    PSU: Corsair HX650
    Watercooling:
    CPU block: EK Supremacy Copper/plexi
    Rads: 2x XSPC EX240 Slim Line Dual Fan
    Fans: BitFenix Spectre White
    Pump: Laing DDC-1Plus MCP355 12V
    Reservoir: EK-DDC X-RES 100 CSQ - Acetal
    Barbs: Bitspower Black Sparkle
    Tubing: Masterkleer - 7/16 ID - 5/8 OD - Clear
    Liquid: Mayhems Pastel Ice White
    Other:
    Case fans: Bitfenix Spectre 140mm in the back
    Some other bits and bobs...
    Here are the first pictures.
    This is a photograph taken somewhere in Iceland over the wintertime
    The Bitfenix prodigy
    The RAM I will be using
    And the case stripped down ready for some modding
  2. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    I like the look of that case. Was thinking of getting myself one. Good luck with your project!
  3. AciD_RaiN
    29 Jul 2012
    Thanks mate :) This case is surprisingly roomy and sturdy... Great build...
  4. AciD_RaiN
    29 Jul 2012
    Well I have done a little modding but it might take a turn. I'm having second thoughts about the front... There is another modder doing a build in that case and some of my ideas are almost identical to his and after watching his videos on his prodigy build I might copy some of it and hope he won't mind.
    I applied some di-noc to the bottom part and it was way harder than I thought so I failed a little there. I hope the top part will be better.
    Then I cut out some of the front part for better airflow.
    After I sanded it down and got it really smooth I painted the cuts with clear nail polish and sanded that down a little and made it as soft as a kittens fur :D
    After I had cut the middle part of the front I realized I might need a plan B so there I might borrow an idea from another great modder if this fails. We will see what happens...
  5. AciD_RaiN
    29 Jul 2012
    Well I have received some more stuff and done a a few things to that case. Been really busy with work and client builds lately and there have been pretty bad storms here so I haven't had any chance to continue...
    I received the GPU the other day.
    Drew the outlines for the windows
    A few days ago I received a nice package from mnpctech
    Went out in the nice weather and made a workbench :D
    Here's the cut after I had filed it down
    And finally with the U-Channel from mnpctech in...
    Not the best job in the world but I'm still evolving :)
  6. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Now, that's dedication. Working with metal in the snow. Awesome. I subbed.
    (However, not a fan of U-channel. Well.... maybe if it was white?)
  7. AciD_RaiN
    29 Jul 2012
    I couldn't find any white and the theme is white, black and light blue so imo it looks great lol. You are more pro than me so you should know more about this stuff. I actually really like that U-Channel :D
  8. spigs_rex
    spigs_rex What's a Dremel?
    1 Oct 2010
    i love these little cases getting modded will be watching
  9. Nutman
    21 Oct 2008
    I just find the U-channel a little too "rough" - and you can always see the join/cut ends.
    Ah, probably just my OCD talking here, but I usually prefer to go for a slightly "cleaner"/different edge.
    How about painting the edges instead?
    Have a look here to see how I did it for "BabyShark".
  10. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Agreed with Nutman - looks cleaner that way :)
  11. Nutman
    21 Oct 2008
  12. djzic
    djzic Bokehlicious!
    8 Nov 2010
    :lol: nice one xD
  13. AciD_RaiN
    29 Jul 2012
    I thought about it but my cuts aren't clean and straight enough and I don't have any place to paint :(
    I was gonna do the other side panel but it's only daylight for a few hours at this time of year so I had to cancel that and tomorrow there's another storm coming :wallbash:
  14. Ra6
    Ra6 What's a Dremel?
    4 Nov 2012
    Great job and nice colours you've chosen!
    Btw LTE for the nickname? ;)
  15. Nutman
    21 Oct 2008
    Aaaaah, Iceland. Where people are weather-beaten, wear funny sweaters and speak funny, too!
  16. Nutman
    21 Oct 2008
    Oh, and probably the only country in the world with heated sidewalks, no?
  17. AciD_RaiN
    29 Jul 2012
    Icelandic originally came from Denmark and we say Danish people talk like they have a potato stuck in their throat lol
    But yeah we have heated sidewalks in some places :p
  18. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    niice gpu! and Glad to see your order arrived safely! and Project is Lookin good too! :rock:
  19. Owndapwn
    Owndapwn What's a Dremel?
    13 Jul 2012
    The black U-channel actually is very fitting for it.
    Contrast is a key design rule, if you take an art or engineering class.
    However, how do you manage to paint in the snow so perfectly?
    I can't even paint in anything less than 50F without the paint sweating and bubbling.
    :'C
    Stupid Icelandic wizards and their magic snow powers.....
  20. AciD_RaiN
    29 Jul 2012
    Arrived and really quickly :) Until next time, thank you so much :)
    I was just cutting in the snow. It's to cold to paint :( But thanks you for that comment on the U-Channel. I think it fits perfectly :D
