Case Mod - In Progress Icelandic Winter worklog
Discussion in 'Project Logs' started by AciD_RaiN, 18 Oct 2012.
  1. AciD_RaiN
    AciD_RaiN New Member
    29 Jul 2012
    Had a really cheap idea. Got some screws and cut off most of it and glued it into the holes in the front. Unbelievable how such a small, cheap thing can make that much of a difference :)
  2. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Wait.... what?
    The front panel wasn't secured with bolts in the first place?
  3. AciD_RaiN
    29 Jul 2012
    The front panel is screwed to the case but the acrylic and fan grill are just stuck on top of the front panel with double sided tape. I made some mistakes in the thinking ahead process so I just had to do it this way...
    The front radiator wouldn't have fitted in line with the grill anyway...
  4. Nutman
    21 Oct 2008
    Oh, ok. Well, I guess you learn as you live. ;)
  5. AciD_RaiN
    29 Jul 2012
    That's what I love about making mistakes... You learn :)
  6. AciD_RaiN
    29 Jul 2012
    Finally getting the motherboard on Monday so I decided to install the LEDs and do as much cable management as possible before the mobo installation. All that is left then is the CPU and liquid ;)
  7. tekonivel
    tekonivel Member
    14 Jul 2012
    Nice and clean. keep up the good work!
  8. AciD_RaiN
    29 Jul 2012
    Thanks mate :) I have already started a new mod but I just need the funds to start properly. I will be selling this one to finance the next one ;)
  9. Lehani
    Lehani New Member
    27 Jun 2012
    so are you droppin' this mod ? or will you finish it ?
  10. AciD_RaiN
    29 Jul 2012
    I will finish it as soon as I can afford a descent CPU for it ;)
    Then I will sell it if I can...
  11. AciD_RaiN
    29 Jul 2012
    I received the motherboard today so I did some more work :)
    Let the fun begin :) BTW cable management is not my strong side...
  12. Nutman
    21 Oct 2008
    Very nice. Gonna use the same mobo for the wifey's upcoming build. Is it any good so far?
  13. AciD_RaiN
    29 Jul 2012
    It looks awesome but I don't have a CPU yet so I don't know if it's any good :p
  14. Cheapskate
    13 May 2007
    Looking sweet.:D
    -One thing:You could lash the gpu power cords to the side of the front fans. It would hide the ugly side of the fans, and straighten your cables in one fell swoop.
    -Ignore me if that was the plan all along.
  15. AciD_RaiN
    29 Jul 2012
    Thanks mate :) I had been thinking about it actually but I probably wouldn't have done it unless someone had pointed it out ;)
  16. jeckulz
    jeckulz New Member
    18 Jan 2011
    Great work mate.
    Nice touch with the old di noc there :)
  17. Meelobee
    Meelobee New Member
    5 Nov 2003
    Can't you route the cables from the videocard up to the roof and then to the front/back?That would give it a much cleaner look.
    Like this:
  18. AciD_RaiN
    29 Jul 2012
    I am pretty sure that was what Cheapskate meant so yes that is the plan :)
  19. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    Looking really nice! I love the bitfenix prodigy!
  20. AciD_RaiN
    29 Jul 2012
    Thanks mate :) I love it too but if I am ever gonna do a build that small I am probably not gonna spend that much on it like I did with this one :p
