Icon Says Wi-Fi not connected when it is
Discussion in 'Tech Support' started by I'm_Not_A_Monster, 7 Oct 2007.
  1. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    i'm running XP SP2 right now on a small maintenance partition before i install Ubuntu 7.04 on the other 130Gb partition, and i'm getting an annoying little quirk with the wireless. the icon on the taskbar has the little red X on it even when i am connected to the internet (including right now).
    how can i fix this?
  2. kenco_uk
    28 Nov 2003
    It's a quirk. I used to get it, too. Are you using the Windows wireless config or the manufacturer's?
    Vista seems (to me) to be able to get it's head round whether you're connected or not.
  3. Firehed
    15 Feb 2004
    Might be you have multiple network adapters showing up in the taskbar. If you've got a disconnected but enabled ethernet port, that could well be the red X. Though considering how long you've been around here, I'm sure you've thought of that already. In which case I'll go with Kenco's approach here, and say it's a quirk and you'll just have to live with it.
  4. I'm_Not_A_Monster
    22 Dec 2003
    it is the wireless icon, double-clicking brings up the microsoft wifi config
