Case Mod - In Progress Icy Blue Angel II
Discussion in 'Project Logs' started by snef, 6 Jun 2014.
  1. snef
    snef What's a Dremel?
    18 May 2014
    Icy Blue Angel
    I choose to do a new build log instead of an update because only I keep only the case, fan, cpu and motherboard
    all other parts will be new
    and go for a full Bitspowers build
    Steps 1: Ordering parts
    Computer parts
    CPU: Intel i5-4670k: received
    Mobo: Asus Gryphon with Armor: received
    Ram: 16BG (4 x 4) Corsair Dominator: Waiting delivery
    GPU: 2 x EVGA SuperClocked 03G-P4-2783-KR GeForce GTX 780: Waiting
    Case: -------------------------------------------
    Power Supply: Silverstone Strider 1000w: received
    SSD: 1 x Kingston HyperX 3K : received
    HD: 1 x Seagate 3TB: received
    Mods Parts
    Sleeving: darkside White, Grey and Blue Sleeving: received
    Led: 4 x led Blue for feets: received
    Case lightning: 3 x DazMode - 12" LED Light - White: Waiting
    GPU backplate: 2 x ColdZero Custom received
    Feet: Fannblade led Feet White : received
    a lot of fan splitter and molex spliter: received
    Paint and a lots of little things
    Cooling
    Case and Radiator fans: 11 x Bitfenix Spectre led Blue: received
    Radiator: 1 x Darkside 360 and 1 x Darkside 240: Waiting
    CPU: Bitspower Summit intel: received
    GPU: 2 x Bitspower VG-NGTX780TI Nickel Plated: received
    Pump: 1 x DDC 3.1: received
    Pump Top: DDc Bitspower Pump top Clear, received
    Reservoir: Bitspower - Z-Tank 150 (Clear Cap) received
    Tubing: E22 plexi tube 12mm/10mm: received
    Coolant: 2 x Mayhems Bluberry: received
    Fittings: a truck load of Bitspower Multi-Link Adapter BP-MBWP-C47: received
    Fittings: Bitspower 90, spacer and rotary 90 degre white fitings: received
    Star working on painting and color test
    loll, no choice on color, my wife want pastel blueberry blue,
    some pics of the summit
    seriously, i like it more than EK supremacy, in real life, look really amazing, more than square EK supremacy (i still like the supremacy)
    i love it with coolant
    just ordered Blue screw for this block and reservoir (Bitspower Upgrade kit)
    ahhh, yeah, not a true all only bitspower parts, DDC heatsink is EK, Bitspower was not available at this time
    all O-rings will be blue (pump, res and fittings)
    Made some color test and I love it, at begening, not sure about 3 color for sleeving,
    I will keep the 3 color idea,
    and what can I say about Bitspower waterblock.................................only QUALITY!, I think they worth every penny but need to test before
    less talking and more picture
    first, made some Color test. simply love Darkside Sleeving,
    Received custom backplate, color match is very good, maybe grey is little bit lighter on sleeving, live with that
    simply love these block
    and try Black and white pics, not sure.....
    more update soon
  2. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    nice gear mate, but wheres the modding? :hehe:
  3. snef
    18 May 2014
    Hi
    a very little update this week end
    Power Supply, this time I tried to paint it with a Gloss finish but still in white
    net the perfect finish as Hannoverfist but its still very good
    pics quality are not so good, took all with my Iphone
    pics of PSU assembled with a custom sticker tomorrow, need to let the paint dry
  4. snef
    18 May 2014
    another little update
    PSU is done
    what do you think?
  5. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
    As always snef, excellent work.
  6. jimbaw
    jimbaw What's a Dremel?
    8 May 2014
    blood angel was my favourite build so I'm really looking forward to this, do you mind me asking where you got the blocks and sleeving from? (you can PM me if you want)
    subbed!
  7. snef
    18 May 2014
    Thanks
    I dont know if i can say it here , if not , moderator can remove it please
    Sleeve is Darkside, order block and sleeve from dazmode.com
  8. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Is it a full sticker covering the entire side of the PSU?
    I like it. Your colour themes always are nice.
  9. snef
    18 May 2014
    yes, cover the entire side,
  10. OrangeClockwerk
    OrangeClockwerk Clockwerk Industries
    28 Jul 2013
    Always awesome work bud, cant wait for more, every one of your builds are incredible!
  11. jimbaw
    8 May 2014
    ok thanks a lot!
    (if I am not mistaken, you are French so: merci beaucoup)
  12. snef
    18 May 2014
    thanks
    yep, but French Canadian from Moncton
  13. snef
    18 May 2014
    Thanks Guys,
    @nass
    yes , its for my wife
    another little Update
    work on paints today instead of OCN Lan Party :cry:
    finished the Power Supply,
    and painted the armor and new memory, (need to change the first post)
    and little touch to ram block, put white vinyl on Nickel
    Just received Fans, will take pics today for sharing tonight
  14. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    This is coming together nicely, great work. Subbed.
    J.
  15. Father Fuzzy
    Father Fuzzy What's a Dremel?
    14 Apr 2014
    If it turns out as good as icy blue angel 1
    Will be a sweet rig
    Gorgeous photo's
  16. Randhart
    Randhart What's a Dremel?
    26 Apr 2014
    @ Snef Dude I love your work, question where did you get them nifty cable organiser thingies keepin everything so damn neat!
  17. snef
    18 May 2014
    Thanks
    From Lutro0 Custom
  18. Hanoverfist
    Hanoverfist What's a Dremel?
    11 May 2014
    Very nice photo work...but what is hidden on PSU pics:confused: Paint turned out really nice and even. :thumb:
  19. snef
    18 May 2014
    Thanks Hanno
    the Blur is for NDA things, will share this great thing really soon :thumb:
  20. Impatience
    Impatience Minimodder
    6 Apr 2014
    NDA... PSU... Silverstone... I'm getting the sneaky feeling this is related to an interview that was posted on the main page today.. ;) If it is, you are one lucky SOAB! :hehe:
    EDIT: Just looked back at that article. The connectors are different to the ones shown in those pictures.. Back in the darkness for me!
