Hi all, have purchased this unit a little while ago. Have put a ntfs formatted 1TB disc in it, recognizes it fine. Have put some files on it via the usb connection using a laptop. So far so good. The files I have put on the disc is divx/xvid. I have put them in a folder structure like this: \VIDEO\Foldername1\file1.avi \VIDEO\Foldername1\file1.srt and so on. Maybe 20 folders, not too much. 30 gigs maybe. If I go via the file menu in the Icy Box, I can access the structure and select my avi file and play it. But it does not recognize/find the subtitle file. I am guessing this only works in Movie Mode, via the Movies menu? And here is my first real problem: If I select Movies, Music or picture, the box just freezes - keeps searching on the harddisk or something, can hear it spinning/working. Doesnt matter if I leave it for hours, nothing happens. The only solution is to pull the power plug. Same thing in Music and picture mode (although I havent put any files of this kind on the disc yet). Thats my biggest problem. Anyone had same issue? Second issue: I have a 1080i/PAL tv connected to it via HDMI. If I select any high resolution in the setup, 720/1080 pix, then the avi files get all wrong scaled - aspect ratio goes out the window. Ok, the files are not that high res, but that shouldnt really matter? Only if I choose 480 pix resolution is the right aspect ratio retained.... grrrrr The manual, btw., is rather useless and only helps with the most basic things. Any help ... pleeeease? It would be greatly appreciated
