Icy Box USB 2.0 External Drive Enclosure
Discussion in 'Article Discussion' started by Fly, 13 Jul 2004.
  1. Fly
    Fly inter arma silent leges
    31 Aug 2001
    Handy to carry around!
    Discuss...
  2. Boon
    Boon What's a Dremel?
    2 Sep 2002
    :eyebrow:
    Good article.. one of the sorts of things I've had on my to buy list for years now.. :hehe:
    heh.. ain't that the truth.
  3. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Might I ask why you had this review on the site at the top of the page all day, yet waited until NOW to post the site link? :eyebrow:
    Either way, this is definitely an item I am going to look into. :thumb:
  4. Explicit
    Explicit What's a Dremel?
    23 Dec 2002
    Dear Fly, that is not KDE it is Gnome...
  5. Guest-16
    Guest-16 Guest
    So its basically the "metal gear box" i have here but with blue lights? The only problem with them is the heat generated and isolating the vibration is a bit hard.
    I use one between lappy and main pc (mostly lappy for extra space) and it works really well on usb2, dont even consider using it on usb1 cause its sooooooo damn slooooooow.
  6. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    Yep, this is just a modified Speeze 'metal gear box' - I don't like how I can't find anywhere on the main 'icy box' site saying 'this is a modified speeze metal gear box' ....
    If anyone in the United States wants to buy one of these enclosures (without the lights though, but with a little modding you could throw some led's in there and make it a lot better) check out this link: http://www.newegg.com/app/viewproductdesc.asp?description=17-145-743&DEPA=1
    Edit: Here's a differently branded one but it has the same lights!
    http://www.newegg.com/app/viewproductdesc.asp?description=17-155-211&DEPA=1
  7. Fly
    31 Aug 2001
    Bah, not used to GUI in linux... amended.
  8. Fly
    31 Aug 2001
    Mac OS X cannot write to NTFS partitions, it can only read from them.
  9. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    I think Boon took it to mean that if you format it in NTFS the only OS you could use it with is the Mac.
  10. Fly
    31 Aug 2001
    Didn't want to push mrHaz' article to second place so soon after posting.
  11. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    these enclosures get around lol.
    I have one branded as a "speed metal box" and my dad has a metal gear branded one.
    I use it for multi-track audio on my laptop (gotta love those pentium m's) when I'm away from my main rig and on the firewire it will do pretty much as many tracks as my main rig lol.
  12. Boon
    2 Sep 2002
    Thanks for clearing that up..:).. All I know about Macs is they look pretty..;)
  13. Jedi
    Jedi What's a Dremel?
    16 May 2004
    nice article, jus saw them on kustompcs yesterday and was like 'aye aye'
    i currently have a western digital 250gb in clear plastic horizontal case with no cooling, soooo hot, any idea what the icy box is like for temperatures?
  14. DeX
    DeX Mube Codder
    22 Jul 2002
    I have a few questions:
    The article on the last page mentions that that bottleneck is the USB 2.0 connection and yet you also say that an ATA66 connector has a bandwidth of 66Mbps and that USB 2.0 has a bandwidth of 480Mbps... surley that would make ATA the bottleneck..?
    I always had the impression that USB 2.0 was much faster than USB 1.1 but still not that fast. I have a USB 2.0 mp3 player (the Nomad Zen) and when I transfer large files from to to my computer it can take a fair while. Also it's impossible to run any programs or media files from the drive without transfering to my local hard drive first. Does this Icy Box allow you to do this? If so what is the performance like? For example if I installed Far Cry on a seperate disk and shoved it into one of these boxes, how long would it take to load a level...?
  15. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    usb2 = 480 mBITS/s
    ata66 = 66 mBYTES/s
    usb is 60mB/s
    however you'd be hardpushed to find a drive that can do that unless you use a raptor or something
    DeX, zen takes ages cos its just a laptop drive, slow++
    assuming it just gets picked up as a mass storage device (which the zens dont) you will be able to run programs/media from it
    but it wont be as fast as an equivilent drive internally
  16. Fly
    31 Aug 2001
    MB = MegaByte
    Mb = Megabit
    As for running farcry from an external USB drive, I have no idea. I suspect that unless the whole level is loaded into memory the USB 2.0 Interface will bottleneck. Small programs shouldn't have such problem as their memory footprint is likely to be small, unless of course there is some kind of dependency or absolute address that points to a required file on the mobile HD or a required entry in the windows registry added at install time.
Tags: Add Tags
