ID cooling fans
Discussion in 'Watercooling' started by Smoked Brisket, 11 Aug 2020.
  1. Smoked Brisket
    Smoked Brisket What's a Dremel?
    28 Apr 2020
  2. David
    David Take my advice — I’m not using it.
    7 Apr 2009
  3. Smoked Brisket
    28 Apr 2020
  4. nikkuzim87
    nikkuzim87 What's a Dremel?
    22 Aug 2020
    Hello,
    I've used them. I don't have any "benchmarking" tools to go off however, they worked well on my se360 rad by EK with lots of airflow pushing through the rads, even at low RPM.
    These fans are not overly quiet for the spec level however, if you run them not at 100% they are acceptable.
    The RGB is nice however, the remote control never worked with mine (i got 2 sets and neither remote worked, no matter what i tried).
    Similar noise performance to my Noctua PPC IP67 140mm 3000rpm fans at 100% - If RGB is not a requirement, I'd recommend the 2000 RPM 120mm PPC noctua IP52 (if noise isn't a requirement) or the Noiseblocker NB-Eloop 12p's if you want slightly quieter with less cooling performance. That's if your budget can stretch a bit
    Similar radiator airflow to the Thermaltake Ring (non-rgb) fans - which i'd recommend over the ID COoling ones if RGB isnt your thing and $ budget is tight
    ^Both of these are just by me listening and feeling airflow around the rads - not scientifically determined
    Hope this helps
    Smoked Brisket likes this.
  5. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    choice 1: buy pastel fans and accept them for what they are
    choice 2: buy BA fans, paint them and accept them for what they are
  6. Smoked Brisket
    28 Apr 2020
    So my head got turned a couple of days ago with the release of Lian Li unifans. Pre-ordered 9 from newegg for the new build. Thax for the help.
