Modding IDE Cables
Discussion in 'Modding' started by KelticFox, 4 Sep 2005.
  1. KelticFox
    KelticFox What's a Dremel?
    2 Mar 2005
    Couple of questions:
    1. Maximum length of IDE Cable?
    2. If you had two machine's and they had a male connector both on the chassis, could you then use a female-female ide cable to make them work?
    (i.e. Having a case full of HDD but having a selctor to select which drive you like to boot)
    3. Maximum number of connectors on a cable with the info you will only be using one device at a time?
    Many Thanks
    Fox
  2. alpha112
    alpha112 Minimodder
    23 Aug 2004
    1) about 50cm
    2) perfectly possible, but only max 50cm controller to drive
    3) as many as you want
    A cheap SCSI would be a good alternative, the max cable length for LVD is about 12m IIRC.
  3. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    usb2.0 is always a good option, if ur not doing raid, not that its faster then scsi in the first place, its not at all, but its easy, and a ide drive > usb2.0 converter can cost you all of 15~20 USD...., plus usb hubs and such are easy
    and usb has a maximum length of well, ive never encountered a usb cable that was too long?, ive had a 20 footer, worked fine
