Windows IDE problem
Discussion in 'Software' started by TheoGeo, 4 Sep 2003.
  1. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    first of all my pc info is in my sig :)
    right i have the following problem, in system devices i have this
    and in my computer i have neither of my cd drives showing (they r both on the same IDE cable)
    it came up after i updated my mobo drivers because my pc kept freezing randomly, it no longer freezes but i have this problem instead
    edit/ winME btw
  2. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    Okay, firstly, how are your drives set up? what device on which port, in which position. Next, you should open the properties for those two devices and see what the error is (why you've got a little exclamation mark beside them). It may just be that you need to reinstall your controller drivers, or similar.
    Cheers and good luck. :thumb:
  3. TheoGeo
    10 Jun 2003
    when i go into properties for the devices and ask it to update the driver it says the best driver is already installed for that piece of hardware and the dialogue box says that "the device is either not present, not working properly or does not have all the drivers installed" and to try upgrading the device drivers, which is precisely what i did and it made em b0rk up in the first place, i cant install the original drivers for them because they r on cd and you can't download em
    edit/ oh yeh and i tried reinstalling the drivers that came with the downloaded update and it didnt work, same error
    edit2/ another thing, formatting aint an option cuz my m8 broke my winME cd and i dont have another copy
  4. Kargin
    18 Sep 2002
    Are you sure you got the correwct drivers for your OS and board/other hardware.
    If you've got hybrid components, make sure you get allt eh appropriate drivers.
  5. sja360
    sja360 What's a Dremel?
    3 Jul 2003
    go into safe mode and remove the primary and secondary, else check in add/remove for the via or intel driver depends wot u got.
    thats all i can think of just now.
    be watchin u guys :D
  6. TheoGeo
    10 Jun 2003
    its definitly the correct drivers, i've checked and double checked, they match exactly.
    i dont know wot else to try, cuz if i delete the drivers then i'll have none and that wont help any
  7. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    Upgrade your os to 98 or better :hehe:
    j/k If you can get it working again and it dosent crash too much stick with ME if you like it.
