IDE SATA Converter question
Discussion in 'Hardware' started by Muzza, 2 Mar 2007.
  1. Muzza
    Muzza What's a Dremel?
    22 Jul 2002
    hi,
    I have a sata-ide converter i bought ages ago, which i ended up not using.
    I noticed on one of the projects here, a converter was being used to convert an ide dvd drive to sata connector so i though i could use mine for that.
    Mine looks exactly like this http://cgi.ebay.co.uk/New-slim-IDE-...6QQihZ014QQcategoryZ74941QQrdZ1QQcmdZViewItem
    If i use it to go from sata drive to motherboard ide, it works fine, but going from ide device (i've tried optical and hd) it doesn't work.
    Does anyone know if this is possible, if mine can't do it a pointer to where i can get one which could would be appreciated?
    Cheers
