Modding idea for drilling plexi
Discussion in 'Modding' started by boardsportsrule, 19 Oct 2005.
  1. boardsportsrule
    boardsportsrule What's a Dremel?
    9 May 2004
    hey, well if any of you have worked with plexi u know that when the bit goes thru the last little bit it sometimes chips... if i were to attach the plexi to a peice of wood(lets say plywood), would it still do this, or since its almost like 1 material it would cut nicely every time? i find that if i go slow and hold the plexi down against the base of the drill press hard enough it cuts nicely, but i have over 200 holes to drill and i dont wanna have to redo it because of 1 screw up...please advise....thanks! :)
  2. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    Yeah I think that does work
  3. boardsportsrule
    9 May 2004
    hmm cool! :)any one know if getting a special plexi cutting bit would be worth it? any REAL benefiets?
  4. Chrizzle
    Chrizzle What's a Dremel?
    6 May 2004
    Yeah, that works great. As does taping it with painter's tape or masking tape. I just finished a huge robotics project that was like 40% plexi and we got the best results from clean, lubricated bits drilled at low RPM over a second surface such as wood. Run-on sentence?
    Oh, and one other tip: when drilling plexi, the smaller the bits of plexi coming out of the hole, the better the cut. If you have big spaghetti-looking strands coming out you know you're melting the plexi. If you're getting little sawdust-looking bits then you're drilling it correctly.
  5. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    It only happens if you apply too much downforce/feed the bit too quickly. It also helps to NOT USE high-speed bits.
    If you're drilling anything larger than 1/4-inch it's best to use a spade bit since they don't have a problem with biting/splitting.
  6. serial_
    serial_ What's a Dremel?
    11 Oct 2005
    Anytime i've ever drilled plexi I've usually asked someone else to hold it, set it over a 2x4 or something similar, and just gone nice and easy, not too fast, not too slow.
    Just have confidence, being afraid of screwing up will usually cause you to do just that.
    - serial_
  7. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    You can always drill 3/4 of the way and turn it over but it would mean that you have to mesure on the other side also.
    I'd go with the clamp real close to the hole and a piece of wood under :thumb:
  8. boardsportsrule
    9 May 2004
    well started the long process of drilling 200+ holes..so far so good...i made a guide thing so i can make a buncha holes along the same line...which helps ALOT for chipping at the end..not sure why...also i hold it and clamp it...no need for wood :) thanks alot :)
  9. serial_
    11 Oct 2005
    ^^ glad you got it figured out.
    - serial_
