does this look **clean**???? nice mod, btw!!!! i was thinking, could you glue the window, onto inside of the case, with impact or something.. you'd need to sand down to like 1/2 the width of the window, so the outside remains the same level as the rest of the case... hmmmmmm ..
i was browsing thru gideotek today and found this sweet window wouldn't mind blacking out a window on my li li. btw, sorry if this is ur case - i kinda stol the pic
thats would look even sweeter if there was some purple light comming outa that window, .... just imagine, lol
flush setting the window like that would be easy if you had access to a belt sander ... just have to be very careful not to remove too much acrylic, less you have a window that stuck out all over ...
i have access to a whole DT department, inlcuding several CAD (computer aided design) cams, hehe .... i think the cad would be gr8 for cutting the guitar shape i want to do
Depending on how thick the perspex is, couldn't you use a router with a bearing on the end to cut the rebate you need?
