Modding Ideas for my matrix-themed mod
Discussion in 'Modding' started by robotguy9000, 19 Jun 2004.
  1. deadly-app
    deadly-app What's a Dremel?
    9 Mar 2004
    haha robot, wassup.
    are you finally going to enact this mod, or just keep talking about it?
  2. robotguy9000
    robotguy9000 What's a Dremel?
    3 Jun 2004
    um.. hi deadly :blah:
    If you're wondering, yes i am going to do this, im leaving for a month so ill start in august. Now go away. :hehe: :hehe: :hehe: lol jk
    Crimson sky, i am going to give you a shout, id really appreciate some advice!
  3. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    What a guy *swoon*
    :D
  4. icarus
    icarus What's a Dremel?
    18 Jan 2004
    i have a cool idea if you got the time and paitence to do it all.
    :dremel:
    step 1
    grab some perspex
    step 2
    print out some matrix symbols
    step 3
    attach them to the perspex and dremel arround the prints so you left with solid matrix symbols
    step 4
    lightly sand them
    step 5
    dremel out the symbol on the case
    step 6
    glue the symbols in
    step 7
    get green leds behind the buggers in varying voltages to give different glow strengths
    and hey prest 3d effect at the front fo your case
    could even use them for power and reset buttons in a different colour
    and for full on replace the hdd activity led with green and the symbol will ficker :D
    hope u like
    idea came from the anti vandal switch idea. :idea:
  5. deadly-app
    9 Mar 2004
    err...
    you know how hard that would be to dremel the code?!
  6. icarus
    18 Jan 2004
    yep thats why i put if you got the time at the top of the message :p
    would look ace tho aye :D
  7. deadly-app
    9 Mar 2004
    i think it would be really hard to make it look nice, with a dremel at least.
    maybe laser cutting it :)
  8. robotguy9000
    3 Jun 2004
    icarus, that is an awesome idea, albeit impossible. :sigh: Dremel disks are just too wide, you'd need a laser-cut. and even then...
    but that is an AWESOME IDEA!!!!
    hm... ill think about some alternative way to do it.
    EDIT- just realized that deadly said to lazer cut it also, but where can you get that done?
    :eyebrow:
  9. deadly-app
    9 Mar 2004
    can anyone say...LUNAGENLABS?!
    :p
  10. icarus
    18 Jan 2004
    sweet idea is it easy to find that kinda thing?
    and is it expensive cos might do something like that with a water flaming water drop idea i have. (water droplet in blue with a red flaming border) :dremel:
  11. deadly-app
    9 Mar 2004
    its pricey, but some of the best looking stuff you can find.
  12. icarus
    18 Jan 2004
    i have to get this done it would look so cool
  13. icarus
    18 Jan 2004
    new idea :idea: :idea: :idea:
    how about this
    use a vibro saw to make the symbols the tidy them up with a sander of sorts
    then rater than cutting the symbols as the symbols are going to be sanded off to make them glow just drill holes in the case glue on and light thru the holes :D
    iam a genius go on admit it :D j/k
  14. Firehed
    15 Feb 2004
    Or instead of paying a fortune to get every one laser cut and then backlight them with different strength LEDs... just get it etched in the window :) Less potential breakage issues too.
  15. icarus
    18 Jan 2004
    not the same effect m8 this is individual 3d glowing decals
  16. Zogthetroll
    Zogthetroll What's a Dremel?
    5 Feb 2004
    if you want cool software, run a search for ZMatrix, its a BACKGROUND program, it scrolls over whatever background you've got on your screen so you don't have to wait for a screensaver. i've got it running semi-transparent over the vector background in WinXP, and it looks sweet. doesn't take a whole lot of memory either. anyway, it'd go nicely with the theme you've got there.
  17. robotguy9000
    3 Jun 2004
    ok, i downloaded zmatrix and its pretty awesome...
    anyways, you know how they have the lcd monitors in the matrix? THey're black and have these really cool burn marks on them; im going to experiment with burning plastic to see what kind of results i can get :lol:
  18. Edhi
    Edhi What's a Dremel?
    2 Sep 2003
    Actually, it's the Logos, not the Hammer :p (can't believe nobody picked up on that one! :D)
    Anyway, this sounds like it could be a REALLY cool mod if you pull it off right. I've never seen that Sentinel model before, and I'm just loving the idea you have for it.
  19. coil
    coil What's a Dremel?
    25 May 2004
    I'd say have the Sentinel half on the top, half on the side, and ripping open a window in the side of the machine. Similar to the "destroyed" look of GoblinTinkerer's Orcish mod, maybe.
  20. robotguy9000
    3 Jun 2004
    yeah, thats eggzactly what i had in mind. Just atach the sentinel arms to the metal scraps... :jawdrop:
