Apple Identifying PowerPC G5 vs Mac pro G5
Discussion in 'Software' started by MaximumShow, 16 Mar 2008.
  1. MaximumShow
    MaximumShow Minimodder
    20 Jan 2003
    Mac newb here... What is the quickest way of identifying if you have been given a PowerPC G5 vs a Mac Pro G5 by external viewing?
    Yes I was given one. :D
  2. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Turn it on and look at the system info, I don't recall there being any external difference.
  3. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Apple logo on the top left of the screen, about this mac.
  4. Firehed
    15 Feb 2004
    Mac Pros aren't G5, they're Intel-based. If it has two optical drive slots on the front, it's a Mac Pro, though I think some of the first MPs may have only had one drive like the old PowerMacs. I think the MP also has more/newer ports (FW800, more USB, etc).
  5. Brett89
    Brett89 Minimodder
    15 Dec 2005
    the amount of fans on the back, old macs 2 fans, new one larger one. I think.
  6. MaximumShow
    20 Jan 2003
    Thanks for the help!
    So It turns out it's a PowerMac G5... dual 2.0 Ghz, 2 GB.
    I haven't really used a Mac much sinceTHESE back from elementary school. Not to look a gift horse in the mouth, but I was hoping it would be a MacPro so I could install bootcamp on it and run XP in addition to OS X on it.
  7. Firehed
    15 Feb 2004
    TBH, you probably won't need to. XP compatibility if needed was the clinching factor when I switched a couple years back now, but after a couple weeks I switched from a half the drive XP partition down to 15GB or so, then removed it entirely. I don't even have a VM available anymore. I've got an XP box downstairs for gaming and that's it, but I find that quite contrary to once-popular rumors, I'm always searching for a Windows equivalent to my Mac software for use at work.
  8. MaximumShow
    20 Jan 2003
    Well I am definitely open minded, but most of what I use is PC only (Vegas mainly). However there are many apps I have been eager to check out, such as Shake, which are OSX only. I'm a video editor, but Final Cut Pro has never been appealing for me so I never made the switch to Mac that a huge percentage of Indie film users have. Vegas is an amazing editing suite but it doesn't get much respect yet because "it's not FCP".
  9. Firehed
    15 Feb 2004
    The OS X-only apps are really the ones worth switching for. Of course that comes across as vendor lock-in to many (and, quite frankly, it is), but most of the apps I use day-to-day on my MBP simply don't have anything remotely near as good on other platforms. Heck, it's almost worth switching just for better font smoothing - it's a tiny thing, but when you're staring at text for eight to twelve hours a day, you'd be amazed what kind of difference it makes.
  10. seebul
    seebul Minimodder
    9 Aug 2005
    Please don't say your talking about sony vegas:grr:
  11. MaximumShow
    20 Jan 2003
    Yes I am. It is an excellent NLE which, like I said, doesn't get much respect cause it isn't FCP or Avid. I have used them all and Vegas fits my workflow much better. It also has more tools that make it better for the "do-it all" crowd. It's also significantly cheaper than the rest as it is trying to gain more market share.
  12. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Vegas definitely isn't Avid, but it's a decent piece of software for what it does. And it's slightly less expensive than Avid. :hehe: Just a bit. Unless we're talking Express. lol.
  13. MaximumShow
    20 Jan 2003
    Sarcasm? Vegas is about 1/5th the price.
    For small to medium sized (or budgeted) projects, Avid doesn't offer much over Vegas.
  14. E.E.L. Ambiense
    26 Jul 2007
    Yeah, just a smidge of scarcasm. LOL.
  15. Firehed
    15 Feb 2004
    That may be true, but for a lot of small to medium sized or low-budget products, you can probably get away with iMovie. Are they doing things that are going to be a whole lot more complicated than adding subtitles and transitions?
  16. MaximumShow
    20 Jan 2003
    Yes, much more.
  17. seebul
    seebul Minimodder
    9 Aug 2005
    ugh Vegas is horrible, personal preference i suppose though. I like FCP to be honest:thumb:
  18. MaximumShow
    20 Jan 2003
    Personal preference is definitely the key. Every NLE has it's advantages and disadvantages so Vegas is far from horrible. I have been an editor for 10 years and Vegas is by far the quickest and best suited to my style.
  19. Cei
    Cei pew pew pew
    22 Mar 2008
    A little late, but there's several easy ways of identifying the differences.
    Mac Pros have dual optical drive slots on the front, even if the machine only has a single drive actually installed. PowerMacs have a single, slightly fatter, slot.
    Mac Pros have more ports on the front - Power, Audio, two horizontal USB, FireWire 400 and FireWire 800. The PowerMacs have Power, Audio, a single USB and a single FireWire 400 slot.
    On the rear, Mac Pros have a single large fan grill (120mm), whereas PowerMacs have a pair of smaller 80mm fans. There's also more ports on the back on the Mac Pro (3 USB for a start).
