Networks Identifying unknown hardware
Discussion in 'Hardware' started by Daedelus, 22 May 2009.
  1. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    I have acquired a couple of old laptops (a Dell and a Thinkpad) with no OS installed and no driver disks. After installing XP most of the device drivers still need to be installed but I'm having problems finding the right ones because I don't actually know what the hardware is.
    I've tried going to Lenovo's and Dell's websites to identify which drivers I need for the models I have but they are not much use.
    Is there some freeware which will audit the hardware and identify it (make, model etc) so I can get the correct drivers?
  2. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    UnknownDeviceIdentifier (This app searches the drivers on chip base) so generic drivers will work.
  3. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    Lenovo you can type the type number into the support page and all available drivers and software are listed, up untill a short while ago you could have simply ran windows update then ran the lenovo system update tool which would have automaticly presented all available drivers and packages such as rescue and recovery, access connections etc. This has been discontinued so you will need to manually load all listed drivers.
    If you system has a finger printer reader this can be complex as there is no "driver" for this as such, I believe this relys on 3rd party software (bio software).
  4. Daedelus
    7 May 2009
    I tried that - tried all the network drivers listed for my model but none of them work.
    It may be that there is a fault with the hardware.
    Thanks for the replies!
  5. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    google the laptop model, should locate a spec sheet and from that can determine which drivers u need
    i've not tried UnknownDeviceIdentifier but def plan to now i know of it
  6. rainbowbridge
    26 Apr 2009
    Expand device manager with the yellow bits and take a screen shot and link it here, let me see, by the way I have been working with lenovo laptops for 13 years and can strip any model and replace any part, so yeah do the screen shot :)
    Edit: Scrub that, you will know what model network card it is because after you put in the type number the next screen will list the full system spec from factory including all internal componets.
    Whats the type number of the lenovo machine?
  7. Daedelus
    7 May 2009
    I'm posting this from work - but I will provide all details/screenshots when I get home :D
    Off the top off my head it's an IBM Thinkpad T42, type 2373 (pre-Lenovo afaik)
    Thanks...
  8. Coxorach1
    Coxorach1 What's a Dremel?
    27 Apr 2009
    To find out what unknown hardware is use a software title called Astra32 it will tell you what it is and help with getting drivers for it.
  9. rainbowbridge
    26 Apr 2009
    need the next three characters for full system ident, post it when your home.:thumb:
  10. BlackWhizz
    17 Jul 2008
    Can you post a log of UnknownDeviceIdentifier?
  11. Daedelus
    7 May 2009
    First of all, I've tried other forums for advice in the past but none have had anywhere near the response I've had from here, so thanks all! :thumb:
    Secondly, the IBM details are:
    T42
    2373-3UU (or could be 300, I think the label has worn off)
    Thirdly, here is the full log from UnknownDeviceIdentifier:
    Device Information Listing for Philip Wade@IBMTHINKPAD - 22/05/2009 19:14:05
    82855PM Processor to I/O Controller
    Vendor: Intel Corporation
    PnpID: PCI\VEN_8086&DEV_3340&SUBSYS_00000000&REV_03
    Details
    Bus 0 (PCI), Device Number 0, Device Function 0
    Vendor 8086h Intel Corporation
    Device 3340h 82855PM Processor to I/O Controller
    Command 0106h (Memory Access, BusMaster, System Errors)
    Status 2090h (Has Capabilities List, Supports Back-To-Back Trans., Received Master Abort, Fast Timing)
    Revision 03h, Header Type 00h, Bus Latency Timer 00h
    Self test 00h (Self test not supported)
    PCI Class Bridge (PCI to HOST)
    Subsystem ID 05291014h Unknown
    Subsystem Vendor 1014h IBM
    Address 0 is a Memory Address (anywhere in 0-4Gb, Prefetchable) : D0000000h
    New Capabilities List Present:
    Vendor-Dependant Capability
    AGP Capability, Version 2.0 (AGP 4x and below support)
    AGP Mode Enabled : Yes
    AGP Speed(s) Supported : 1x 2x 4x, Currently : 4x
    FW Transfers Supported : Yes, Enabled : Yes
    >4Gb Address Space Supported : No, Enabled : No
    Sideband Addressing Supported : Yes, Enabled : Yes
    Maximum Command Queue Length : 32 bytes, Current Queue Length : 1 byte
    Class: Bridge (PCI to HOST)
    OEM Device: Unknown
    OEM Vendor: IBM
    82855PM Processor to AGP Controller
    PnpID: PCI\VEN_8086&DEV_3341&SUBSYS_05291014&REV_03
    Details
    Bus 0 (PCI), Device Number 1, Device Function 0
    Device 3341h 82855PM Processor to AGP Controller
    Command 0107h (I/O Access, Memory Access, BusMaster, System Errors)
    Status 00A0h (Supports 66MHz, Supports Back-To-Back Trans., Fast Timing)
    Revision 03h, Header Type 01h, Bus Latency Timer 60h
    PCI Class Bridge (PCI to PCI)
    PCI Bridge Information:
    Primary Bus Number 0, Secondary Bus Number 1, Subordinate Bus Number 1
    Secondary Bus Command 000Ch (ISA mapping, VGA mapping)
    Secondary Bus Status 22A0h (Supports 66MHz, Supports Back-To-Back Trans., Received Master Abort,
    Medium Timing)
    Secondary Bus Latency 40h
    I/O Port Range Passed to Secondary Bus : 3000h to 3FFFh (16-bit I/O space)
    Memory Range Passed to Secondary Bus : C0100000h to C01FFFFFh
    Prefetchable Memory Range Passed to Secondary Bus : E0000000h to E7FFFFFFh
    Class: Bridge (PCI to PCI)
    82801DB/DBL USB UHCI Controller #1 (ICH4/ICH4-L A1 step)
    PnpID: PCI\VEN_8086&DEV_24C2&SUBSYS_00000000&REV_01
    Details
    Bus 0 (PCI), Device Number 29, Device Function 0
    Device 24C2h 82801DB/DBL USB UHCI Controller #1 (ICH4/ICH4-L A1 step)
    Command 0005h (I/O Access, BusMaster)
    Status 0280h (Supports Back-To-Back Trans., Medium Timing)
    Revision 01h, Header Type 80h, Bus Latency Timer 00h
    PCI Class Serial (USB (UHCI))
    Subsystem ID 052D1014h Unknown
    Address 4 is an I/O Port : 00001800h
    System IRQ 11, INT# A
    Class: Serial (USB (UHCI))
    OEM Device: Unknown
    OEM Vendor: IBM
    System IRQ: 11, INT# A
    82801DB/DBL USB UHCI Controller #2 (ICH4/ICH4-L A1 step)
    PnpID: PCI\VEN_8086&DEV_24C4&SUBSYS_052D1014&REV_01
    Details
    Bus 0 (PCI), Device Number 29, Device Function 1
    Device 24C4h 82801DB/DBL USB UHCI Controller #2 (ICH4/ICH4-L A1 step)
    Revision 01h, Header Type 00h, Bus Latency Timer 00h
    Address 4 is an I/O Port : 00001820h
    System IRQ 11, INT# B
    OEM Device: Unknown
    OEM Vendor: IBM
    System IRQ: 11, INT# B
    82801DB/DBL USB UHCI Controller #3 (ICH4/ICH4-L A1 step)
    PnpID: PCI\VEN_8086&DEV_24C7&SUBSYS_052D1014&REV_01
    Details
    Bus 0 (PCI), Device Number 29, Device Function 2
    Device 24C7h 82801DB/DBL USB UHCI Controller #3 (ICH4/ICH4-L A1 step)
    Address 4 is an I/O Port : 00001840h
    System IRQ 11, INT# C
    OEM Device: Unknown
    OEM Vendor: IBM
    System IRQ: 11, INT# C
    82801DB/DBL USB 2.0 EHCI Controller (ICH4/ICH4-L A1 step)
    PnpID: PCI\VEN_8086&DEV_24CD&SUBSYS_052D1014&REV_01
    Details
    Bus 0 (PCI), Device Number 29, Device Function 7
    Device 24CDh 82801DB/DBL USB 2.0 EHCI Controller (ICH4/ICH4-L A1 step)
    Status 0290h (Has Capabilities List, Supports Back-To-Back Trans., Medium Timing)
    PCI Class Serial (USB 2.0 (EHCI))
    Subsystem ID 052E1014h Unknown
    Address 0 is a Memory Address (anywhere in 0-4Gb) : C0000000h
    System IRQ 11, INT# D
    Power Management Capability, Version 1.1
    Does not support low power State D1 or D2
    Supports PME# signalling from mode(s) D0, D3hot, D3cold
    PME# signalling is currently disabled
    Current Power State : D0 (Device operational, no power saving)
    3.3v AUX Current required : 375mA
    USB 2.0 EHCI Debug Port Capability
    Class: Serial (USB 2.0 (EHCI))
    OEM Device: Unknown
    OEM Vendor: IBM
    System IRQ: 11, INT# D
    82801 Family (ICH2/3/4/5/6/7/8/9-M) Hub Interface to PCI Bridge
    PnpID: PCI\VEN_8086&DEV_2448&SUBSYS_052E1014&REV_81
    Details
    Bus 0 (PCI), Device Number 30, Device Function 0
    Device 2448h 82801 Family (ICH2/3/4/5/6/7/8/9-M) Hub Interface to PCI Bridge
    Status 8080h (Supports Back-To-Back Trans., Detected Parity Error, Fast Timing)
    Revision 81h, Header Type 01h, Bus Latency Timer 00h
    Primary Bus Number 0, Secondary Bus Number 2, Subordinate Bus Number 8
    Secondary Bus Command 0004h (ISA mapping)
    Secondary Bus Status 2280h (Supports Back-To-Back Trans., Received Master Abort, Medium Timing)
    Secondary Bus Latency A8h
    I/O Port Range Passed to Secondary Bus : 4000h to 8FFFh (16-bit I/O space)
    Memory Range Passed to Secondary Bus : C0200000h to CFFFFFFFh
    Prefetchable Memory Range Passed to Secondary Bus : E8000000h to EFFFFFFFh
    82801DBM (ICH4-M) LPC Interface Bridge
    PnpID: PCI\VEN_8086&DEV_24CC&SUBSYS_00000000&REV_01
    Details
    Bus 0 (PCI), Device Number 31, Device Function 0
    Device 24CCh 82801DBM (ICH4-M) LPC Interface Bridge
    Command 000Fh (I/O Access, Memory Access, BusMaster, Special Cycles)
    PCI Class Bridge (PCI to ISA)
    Class: Bridge (PCI to ISA)
    82801DBM (ICH4-M) UltraATA/100 EIDE Controller
    PnpID: PCI\VEN_8086&DEV_24CA&SUBSYS_00000000&REV_01
    Details
    Bus 0 (PCI), Device Number 31, Device Function 1
    Device 24CAh 82801DBM (ICH4-M) UltraATA/100 EIDE Controller
    Command 0007h (I/O Access, Memory Access, BusMaster)
    PCI Class Storage (IDE (ATA)
    PCI EIDE Controller Features :
    BusMaster EIDE is supported
    Primary Channel is at I/O Port 01F0h and IRQ 14
    Secondary Channel is at I/O Port 0170h and IRQ 15
    Address 0 is an I/O Port : 00000000h
    Address 1 is an I/O Port : 00000000h
    Address 2 is an I/O Port : 00000000h
    Address 3 is an I/O Port : 00000000h
    Address 4 is an I/O Port : 00001860h
    Address 5 is a Memory Address (anywhere in 0-4Gb) : FEBFFC00h
    Class: Storage (IDE (ATA)
    OEM Device: Unknown
    OEM Vendor: IBM
    82801DB/DBL SMBus Controller (ICH4/ICH4-L A1 step)
    PnpID: PCI\VEN_8086&DEV_24C3&SUBSYS_052D1014&REV_01
    Details
    Bus 0 (PCI), Device Number 31, Device Function 3
    Device 24C3h 82801DB/DBL SMBus Controller (ICH4/ICH4-L A1 step)
    Command 0001h (I/O Access)
    PCI Class Serial (SMBus Controller)
    Address 4 is an I/O Port : 00001880h
    Class: Serial (SMBus Controller)
    OEM Device: Unknown
    OEM Vendor: IBM
    82801DB/DBL AC'97 Audio Controller (ICH4/ICH4-L A1 step)
    PnpID: PCI\VEN_8086&DEV_24C5&SUBSYS_052D1014&REV_01
    Details
    Bus 0 (PCI), Device Number 31, Device Function 5
    Device 24C5h 82801DB/DBL AC'97 Audio Controller (ICH4/ICH4-L A1 step)
    PCI Class Multimedia (Audio)
    Subsystem ID 05371014h SoundMAX Integrated Digital Audio
    Address 0 is an I/O Port : 00001C00h
    Address 1 is an I/O Port : 000018C0h
    Address 2 is a Memory Address (anywhere in 0-4Gb) : C0000C00h
    Address 3 is a Memory Address (anywhere in 0-4Gb) : C0000800h
    Class: Multimedia (Audio)
    OEM Device: SoundMAX Integrated Digital Audio
    OEM Vendor: IBM
    82801DB/DBL AC'97 Modem Controller (ICH4/ICH4-L A1 step)
    PnpID: PCI\VEN_8086&DEV_24C6&SUBSYS_05371014&REV_01
    Details
    Bus 0 (PCI), Device Number 31, Device Function 6
    Device 24C6h 82801DB/DBL AC'97 Modem Controller (ICH4/ICH4-L A1 step)
    PCI Class Simple Communication (Hayes Compatible Modem)
    Subsystem ID 055A1014h Unknown
    Address 0 is an I/O Port : 00002400h
    Address 1 is an I/O Port : 00002000h
    Class: Simple Communication (Hayes Compatible Modem)
    OEM Device: Unknown
    OEM Vendor: IBM
    Mobility Radeon 9700 (M10 NP) (RV350)
    Vendor: ATI Technologies Inc
    PnpID: PCI\VEN_1002&DEV_4E50&SUBSYS_055A1014&REV_00
    Details
    Bus 1 (AGP), Device Number 0, Device Function 0
    Vendor 1002h ATI Technologies Inc
    Device 4E50h Mobility Radeon 9700 (M10 NP) (RV350)
    Command 0307h (I/O Access, Memory Access, BusMaster, System Errors, Back-To-Back Transactions)
    Status 02B0h (Has Capabilities List, Supports 66MHz, Supports Back-To-Back Trans., Medium Timing)
    Revision 00h, Header Type 00h, Bus Latency Timer 42h
    Minimum Bus Grant 08h, Maximum Bus Latency 00h
    Cache line size 32 Bytes (8 DWords)
    PCI Class Display (VGA)
    Subsystem ID 05501014h Unknown
    Address 0 is a Memory Address (anywhere in 0-4Gb, Prefetchable) : E0000000h
    Address 1 is an I/O Port : 00003000h
    Address 2 is a Memory Address (anywhere in 0-4Gb) : C0100000h
    Expansion ROM of 128Kb decoded by this card (Currently disabled)
    Maximum Command Queue Length : 80 bytes, Current Queue Length : 32 bytes
    Supports low power State D1
    Supports low power State D2
    Does not support PME# signalling
    Class: Display (VGA)
    OEM Device: Unknown
    OEM Vendor: IBM
    PCI4520 PC Card CardBus Controller
    Vendor: Texas Instruments (TI)
    PnpID: PCI\VEN_104C&DEV_AC46&SUBSYS_05501014&REV_01
    Details
    Bus 2 (PCI), Device Number 0, Device Function 0
    Vendor 104Ch Texas Instruments (TI)
    Device AC46h PCI4520 PC Card CardBus Controller
    Status 0210h (Has Capabilities List, Medium Timing)
    Revision 01h, Header Type 82h, Bus Latency Timer 40h
    PCI Class Bridge (PCI to Cardbus)
    Subsystem ID 05521014h Unknown
    CardBus Bridge Information:
    PCI Bus Number 2, CardBus Bus Number 3, Subordinate Bus Number 5
    CardBus Bus Status 0200h (Medium Timing)
    CardBus Latency B0h ExCA Base Memory Address : B0000000h Memory Range 0 Passed to Secondary
    Bus : FEBFE000h to FEBFEFFFh
    Memory Range 1 Passed to Secondary Bus : FABFE000h to FEBFDFFFh
    I/O Port Range 0 Passed to Secondary Bus :
    FE00h to FEFFh (16-bit)
    I/O Port Range 1 Passed to Secondary Bus :
    FD00h to FDFFh (16-bit)
    Supports PME# signalling from mode(s) D0, D1, D2, D3hot, D3cold
    3.3v AUX Current required : 0mA (Self powered)
    Class: Bridge (PCI to Cardbus)
    OEM Device: Unknown
    OEM Vendor: IBM
    OEM Device: Unknown
    OEM Vendor: IBM
    82540EP Gigabit Ethernet Controller (Mobile)
    PnpID: PCI\VEN_8086&DEV_101E&SUBSYS_05521014&REV_03
    Details
    Bus 2 (PCI), Device Number 1, Device Function 0
    Device 101Eh 82540EP Gigabit Ethernet Controller (Mobile)
    Command 0100h (Bus Access Disabled!!, System Errors)
    Status 0230h (Has Capabilities List, Supports 66MHz, Medium Timing)
    Revision 03h, Header Type 00h, Bus Latency Timer 40h
    Minimum Bus Grant FFh, Maximum Bus Latency 00h
    PCI Class Network (Ethernet)
    Subsystem ID 05491014h PRO/1000 MT Mobile Connection
    Address 0 is a Memory Address (anywhere in 0-4Gb) : C0240000h
    Address 1 is a Memory Address (anywhere in 0-4Gb) : C0200000h
    Address 2 is an I/O Port : 00008000h
    Expansion ROM of 64Kb decoded by this card (Currently disabled)
    PME# signalling is currently enabled
    Current Power State : D3hot (Device off: no power to device, maximum power saving)
    Class: Network (Ethernet)
    OEM Device: PRO/1000 MT Mobile Connection
    OEM Vendor: IBM
    11a/b/g Wireless LAN Mini PCI Adapter
    Vendor: Atheros Communications Inc
    PnpID: PCI\VEN_168C&DEV_1014&SUBSYS_05491014&REV_01
    Details
    Bus 2 (PCI), Device Number 2, Device Function 0
    Vendor 168Ch Atheros Communications Inc
    Device 1014h 11a/b/g Wireless LAN Mini PCI Adapter
    Command 0116h (Memory Access, BusMaster, MemWrite+Invalidate, System Errors)
    Revision 01h, Header Type 00h, Bus Latency Timer 50h
    Minimum Bus Grant 0Ah, Maximum Bus Latency 1Ch
    Subsystem ID 833117ABh 11a/b/g Wireless LAN Mini PCI Adapter
    Subsystem Vendor 17ABh Phillips Components
    Address 0 is a Memory Address (anywhere in 0-4Gb) : C0210000h
    Power Data Registers Information: D0 Power Consumed: 1980mW D1 Power Consumed: 1980mW
    D2 Power Consumed: 1980mW D3 Power Consumed: 60mW D0 Power Dissipated: 1980mW D1 Power
    Dissipated: 1980mW D2 Power Dissipated: 1980mW D3 Power Dissipated: 60mW
    OEM Device: 11a/b/g Wireless LAN Mini PCI Adapter
    OEM Vendor: Phillips Components
  12. Daedelus
    7 May 2009
    Thanks for all the responses, best forum by far for this :thumb:
    It's an IBM Thinkpad T42 type 2373-3UU (or could be 300, I think the label has worn off)
    I can't post the full log, it's too long, but here's the section for the wireless adapter:
    Details
  13. Daedelus
    7 May 2009
    And here is the full log:
    Device Information Listing for xxxxxxxx@IBMTHINKPAD - 22/05/2009 19:14:05
    Details
    OEM Device: Unknown
    OEM Vendor: IBM
    Details
    Medium Timing)
    Details
    OEM Device: Unknown
    OEM Vendor: IBM
    Details
    OEM Device: Unknown
    OEM Vendor: IBM
    Details
    OEM Device: Unknown
    OEM Vendor: IBM
    Details
    OEM Device: Unknown
    OEM Vendor: IBM
    Details
    Details
    Details
    OEM Device: Unknown
    OEM Vendor: IBM
    Details
    OEM Device: Unknown
    OEM Vendor: IBM
    Details
    OEM Vendor: IBM
    Details
    OEM Device: Unknown
    OEM Vendor: IBM
    Details
    OEM Device: Unknown
    OEM Vendor: IBM
    Details
    OEM Device: Unknown
    OEM Vendor: IBM
    OEM Device: Unknown
    OEM Vendor: IBM
    Details
    OEM Vendor: IBM
    Details
  14. glendronach
    glendronach What's a Dremel?
    1 May 2009
    Aaaaaaargh! Too much info
    Simply open Device Manager and open Properties for the unknown devices.
    Select Details tab and make a note of the Device Instance id. Post the ids back here and usually they can be converted to the exact hardware.
    There is always a concern with laptops that some hardware is specific to the manufacturer and drivers for the same hardware will not work for another make using the same hardware.
    Most of the Lenovo hardware is Intel.
    Any id that says PnpID: PCI\VEN_8086 hardware means Intel so should be easy to figure out.
  15. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    Try searching for the vendor and device IDs (168C 1014) That might net you some generic drivers.
  16. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
  17. rainbowbridge
    26 Apr 2009
    Product support
    Product: ThinkPad T42 2373-3UU [change]
    Operating system: All [change]
    Original description: P M 735, 512MB RAM, 40GB 5400rpm HDD, 14.1 SXGA+(1400x1050) TFT LCD, 64MB ATI Radeon 9600, 24x24x24x/8x CD-RW/DVD, IBM 802.11a/b/g wireless(MPCI), Bluetooth/Modem(CDC), 1Gb Ethernet(LOM), UltraNav, Secure Chip, 6 cell Li-Ion battery, WinXP Pro
    Drivers and software - ThinkPad T42, T42p
    Here
    Start at the top and work your way down, there is only one networking option.
    Networking:
    Ethernet T42/p
    Intel PRO/100/1000 LAN adapter
    Windows Vista 21 Feb 2007
    Build 135400
    Windows XP, 2000 28 Feb 2007
    Build 135400
    Windows 98, NT 22 Apr 2005
    Build 73398
    DOS, and OS/2 22 Apr 2005
    Build 73398
    Post back with further questions as maybe required :thumb:
  18. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
  19. Krikkit
    21 Jan 2003
    For the IBM have a look at the model-specific page here.
    Follow the link and it'll tell you which files you need to download.
    For the dell it can be a real pain to get drivers, but it should have the model number written on it somewhere.
