News IDF News: BTX update
Discussion in 'Article Discussion' started by WilHarris, 11 Sep 2004.
  1. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
    Intel have been talking up BTX here this week, despite the apparent reluctance of the rest of the industry to move to the form factor.
    BTX is the first major evolution of the PC form factor since 1995, when ATX launched. Unlike ATX, which had a very quick uptake, we are yet to see any systems or cases using it other than prototypes, despite the fact that BTX launched last year and is an open standard. In fact, even Intel's own predictions state that BTX will take until 2007 to even ship in half of new systems.
    The BTX standard proposes to cut down on the number of fans in a system. With a single 120mm at the front, ducted over the processor, and the PSU fan venting out the back, adequate system temperatures can be maintained. In fact, adding an extra fan to the chassis can degrade performance, due to the way BTX keeps airflow running.
    BTX not only has a standard for standard tower PCs, but also for mini Shuttle-esque systems, called picoBTX. This means that you'll be able to buy standard SFF components and mix and match them with cases, rather than buying an entire barebones solution. picoBTX motherboards are around 27x20cm - ideal for modding!
    We're taking to different companies about BTX, to get their opinions on where this new form factor is going. Look for a follow-up article here soon.
  2. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    picoBTX eh? not leaving much room for if they decide to make a smaller one are they? Pretty much stuck with femtoBTX.
  3. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    just a note, the CM stacker supports BTX :)
  4. Xipher
    Xipher What's a Dremel?
    25 Apr 2004
    From what I hear, its a PITA to change it over though.
  5. apollyon
    apollyon What's a Dremel?
    20 Apr 2004
    I've actually seen a BTX system, gateway has had one out for about a month now that i've had in at work (best buy). It does seem to be fairly efficient cooling, however I haven't had a chance to check temperatures, and i don't think that my managers would be to happy if i overclocked our display model :D
    I'm wondering when the industry as a whole is going to get away from fan cooling anyways, I've had a Sony in for some time now that uses heatpiping, much quieter then fans and fairly efficient.
  6. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    And the new lian lis i think :)
  7. Hephaistus
    Hephaistus What's a Dremel?
    11 Mar 2004
    What new lian li supports BTX ????
    The v1000, v1100, v1200, v2000,... does not support BTX, it's just ATX but turned around.
    Or is there a new lian-li that i haven't heard of. :confused:
  8. NemyMongus
    NemyMongus What's a Dremel?
    28 Jul 2004
    No I think he is referring to the V series. I haven't seen anything that is true BTX from Lian-Li yet.
Tags: Add Tags
