Hardware IDF Spring 2007 - Benchmarking Penryn
Discussion in 'Article Discussion' started by The_Pope, 18 Apr 2007.
  1. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
  2. DougEdey
    5 Jul 2005
    You did what now?
    Those figures do look nice, but the how much is applicable to the larger L2 and how much to the higher FSB
  3. Mary Jo
    Mary Jo oh lolz
    13 Oct 2004
    This doesn't read correctly.
  4. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    Out of slight curiosity could you overclock a QX6700 to 3.33GHz (on a 1333Mhz FSB) and compare the quad core Penryn numbers clock-for-clock?
  5. Tim S
    Tim S OG
    8 Nov 2001
    Thanks, this was a time sensitive piece and I wasn't available to proof the article before being published. Thus, there were a few errors not picked up by the other proofers.
  6. Tim S
    Tim S OG
    8 Nov 2001
    It's certainly possible to create a system similar to that in our offices, as our QX6700 was capable of 3.46GHz using multiplier changes. We'll have to see.
  7. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    yeah that would be excellent.
    to try and see what they rate at clock for clock would be great
    my question tho is surely with a few OC'ers going upwards of 5Ghz would it be likely we will see a few penryn going upwards of 6Ghz and therefore possibly sub 8 sec super pi runs
  8. Guest-16
    Guest-16 Guest
    We wanted to but they actually wouldnt let us play with the systems. This was our exact argument but they were having none of it.
    Fixed! The processors are exactly the same as what you can buy but because the 45nm process is so new, the yields are still poor and the cost per chip is still exceptionally high. Therefore supplying the press with samples would cost Intel far too much, instead we'll have to wait a few months.
    Subst the s for a d :rolleyes: they are next to each other on the kb!
    I was quoted "12% to clock speed, 14% to cache" but that was under a certain circumstance I can't seem to find now. It depends on what you're running: if the data can fit in cache then it'll be cache dependent, otherwise it'll be FSB since it'll be accessing memory.
  9. mclean007
    mclean007 Officious Bystander
    22 May 2003
    And Intel get the prize for least scientific performance demonstration this year. Wow a new architecture running at higher FSB and higher clock gives a better performance...who would have guessed?! They really should have had Penryn at stock, QX6800 at stock, and then either Penryn at 11 x 266 or QX6800 @ 10 x 333. Without that, the numbers are meaningless!
    Still, subject to all these caveats, there is massive potential, particularly in that encoding score!
  10. JADS
    27 Mar 2001
    As Tim mentioned you can replicate a 3.33GHz Kentsfield in the lab and do a direct comparison so it should give a better indication of the potential performance improvement.
    Penryn good, Nehalem better :)?
  11. Tim S
    Tim S OG
    8 Nov 2001
    Providing Rich can get the source material used in the benchmarks.
  12. Mary Jo
    Mary Jo oh lolz
    13 Oct 2004
    Nice one. Good report - can't wait until someone gets their hands on one of these for some intensive testing. :)
  13. Grinch123456
    Grinch123456 What's a Dremel?
    9 Aug 2006
    If this is to be believed, AMD better do something fast.
  14. Nictron
    Nictron Minimodder
    16 Feb 2007
    AMD where art thou!
  15. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    :clap:
  16. speedfreek
    speedfreek What's a Dremel?
    9 Nov 2005
    I thought the same, what do they have to worry about if there new design is so much better than a simple die shrink.
  17. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    exactly what i was thinkin.
    My AM2 board, which i was under the impression would be future proof for at least 18 months is lookin more and more outdated by the day.
    I so wish i'd bought a 775 and C2D... we live and learn.
  18. Guest-16
    Guest-16 Guest
    To make it properly scientific you'd want to use exactly the same system and benchmarks for both tests, setup by just one person.
  19. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Would be good to see some dual core compare's too if possible. Know you stated you'd need exactly the same setup etc which is fair enough, but it'd be nice to get a ballpark figure for the performance improvement (or not).
    The clockspeed defecit the Q6800 has over the other quad would certainly be MUCH lower if the clockspeeds were matched, the extra bus speed might well help things to an extent too. (could also be worth changing the labelling here, as the QX6800 isnt labelled as quad core which could cause confusion)
    Clock for clock, things don't look a _huge_ amount quicker. From Intels point of view I guess it makes sense for them NOT to overclock one/underclock another as the performance difference between the chips would certainly be less marked than these stock runs with the large clock speed discrepancies
Tags: Add Tags
