Modding Idiots guide to LCD's please...
Discussion in 'Modding' started by Mr T, 14 Nov 2001.
  1. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    im from the UK and reallywant a LCD for as cheep as possable it can be Paralell or Serial but must be cheep can anyone help.
    P.S. I have access ti maplin for parts if ya can get em there.
  2. ZeffriN
    ZeffriN What's a Dremel?
    11 Sep 2001
    I believe you can get an industry standard LCD from maplin although I don't know codes or anything like that.
    However, check out wiring guide here...
    http://www.overclockers.com.au/techstuff/a_diy_lcd/
    It'll set you back price of LCD, a printer cable (possibly a connector instead if you wanna do a good job on it)
    and a molex
    Pretty good way to have an LCD on the cheap!
  3. Cheese
    Cheese Doc
    6 Oct 2001
  4. Homer-J
    Homer-J What's a Dremel?
    6 Nov 2001
    Hi, the following are prices and codes for maplins parallel LCD's they all use Hitachi HD44780 compatible display controlers:
    RM88V - 2x16 - £11.055
    RM89W - 2x20 - £25.523
    RM90X - 2x40 - £34.034
    RM91Y - 4x20 - £34.034
    All prices above include VAT
    I have the RM91Y LCD and it works great with LCDCenter, Winamp plugins etc..
    Note: Chris -[tBG] on this forum bought RM88V and couldnt get it to work, not sure why, but this is just a word of warning.
    Hope this helps.
  5. Mr T
    14 Nov 2001
    Thanks hopwfully should be trying the printer cable one soon :)
