CPU Idle I5-2500k temps
Discussion in 'Hardware' started by Kensei79, 9 Mar 2012.
  1. Kensei79
    Kensei79 What's a Dremel?
    8 Mar 2012
    Ok so I hope this is the right place as this is my first forum post... I need a little help
    I'm trying to build my first pc. I've got the following kit and as I've just powered it up to text it before putting it in the case.
    I5-2500k
    MSI P67A-GD53
    Be Quiet Advanced
    2 x 2GB and 1 x 4GB Corsair Vengeance DDR3 Ram
    Antec 650 true power PSU
    AMB Raedon 6870
    Now I've just plugged it all in and got into the bios. My CPU temp was around 64C idle. Too high I knew enough so I took the kit apart again and decided a little more TIM was needed and reconnected the cooler and everything else (one of the screws was off so could have had a not so great fit to the cpu there) and powered it up and I'm still running at a idle CPU temp of 52-54C
    This still seems too high.
    As Custom PC guide I was going by suggested applying the TIM to the CPU before putting it in its slot I did that. Because I had trouble attaching the cooler there was now I think about it a maybe 3 hour gap between putting the TIM on the CPU and managing to attached the cooler (had to go out :( )
    Any suggestions as too why I'm still running at 52-54C? Could it be as simple as the TIM dried out because i didn't attach the cooler quickly enough? The cooler is now attached as tightly as I dare. And its already leaning on the RAM stick in the second slot away from the CPU so not sure i could tighten the fitting of the cooler.
    IS 52-54C ok for an idle temp? If not what should I do to fix it?
  2. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    What case are you using? Did you remove the protective clear plastic cover from the heatsink base?
  3. Kensei79
    8 Mar 2012
    Yes I did removed the plastic from base of the heatsink, As for the case I've not actually got it in the case yet. The Custom PC build guide I was using as a reference says to test the kit outside the case first and if the temps are over 50C then you've got a problem. So I was really working to that. When I put power though the board its just sitting on the motherboard box with the cooler, graphics card RAM attached.
    Interestingly I tried the stock cooler as well after posting this thread and got a idle temp of 54-57C. Thought a Dark Rock Advanced was supposed to be better
  4. law99
    law99 Custom User Title
    24 Sep 2009
    You have to remove the plastic cover? News to me. :D
  5. longweight
    7 May 2011
    Hmm if the cooler is seated correctly and tightly and you have connected the fan header then I would think that the sensor is faulty.
    What happens when you get to Windows and try with something like RealTemp?
    That is far too high for idle, my i5 in an FT02 idles at 29-32 and in game it maxes out at 60.
  6. Da_Rude_Baboon
    28 Mar 2002
    Hey i've been building PC's for over ten years and I missed it once. :D PC was idling at 60c, removed the heatsink, cleared the TIM which came off far too easily. Then I noticed it had a clear sticky plastic cover that fitted the cooler base exactly with no overhang so I hadn't noticed it. :duh: I'm amazed it had not melted.
  7. DaveMon
    DaveMon The end is nigh! Repent!
    21 Jun 2010
    My idle temps currently:
    25~30C
    My load temps are the same as your idle.
    Max temp in BF3 is 54-55C
  8. law99
    24 Sep 2009
    Lol. I suppose its bound to happen by accident some time!
  9. S1W1
    S1W1 Minimodder
    25 Mar 2011
    Those temperatures are certainly higher than they should be. I built a PC for a friend a few weeks ago with the same CPU and cooler as you- idle temperatures were in the low 30s.
    A mistake I made when I built my first PC- what direction is the fan on the BeQuiet! Dark Rock Advanced facing? If it's mounted the wrong way round it will be pulling air away from the exhaust fan and dumping it back into the case. That's quite a common error. The fan on the BQ Dark Rock Advanced pushes (NOT pulls) air through the heat sink, if that makes sense.
    However from what you've said, the problem is probably with the RAM- that Vengeance RAM has great big heat spreaders and that will be preventing the HSF from making proper contact with the CPU. You should possibly have bought the low profile Vengeance RAM- it would fit under the heatsink much more easily and offer the same good performance and value as the normal Vengeance.
    Before you replace the RAM however, check/do the following:
    -Remount the cooler with fresh thermal paste. You will have to clean the old stuff off the CPU and off the heat sink before you can reinstall it.
    -Make sure the cooler is mounted facing the correct direction.
    -Make sure you have not left the plastic on the bottom of the heatsink- it happens easily.
    BTW what case are you using?
  10. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    lulz if you did this op :p thats quite amusing
    my 2600k idles at 28 on low case fans, and 26 on high case fans, with an ambient temp of about 18-19 degrees c
    idle voltage is 1.064
  11. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Try with just one stick of ram in the furthest away slot, should give you room to tighten it up properly.
    Also, do bear in mind that if you are checking temps in the bios speedstep won't be working, so you will have much higher temps. I sit at about 40-45 in the bios when using a stock cooler, but drop to 25-30 when in windows.
  12. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    With mine clocked to 4.5 on a dark rock sits around 28c in bios usually
  13. megadriveguy
    megadriveguy Minimodder
    19 May 2010
    Either the volts are crazy high
    Or the heatsink isn't fitted properly
    It cant be the fan you'd get better temps than that without a fan
  14. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Download something like core temp and check the temps in windows. If that reports it as much lower then i suggest flashing your bios.
    good luck.
  15. Bede
    Bede Minimodder
    30 Sep 2007
    OP's location? If his room temp is 35C because he lives in a desert that could explain things :D
  16. Kensei79
    8 Mar 2012
    Hi all, thanks for the suggestions I seemed to have got it fixed. I had trouble fitting the heatsink to start with due to its sheer size i think. Bought some TIM cleaner and a new TIM. cleaned, re apploied and the BIOS temp was around 42C.
    Once I got the pc up and running and installed Core Temp which now has my cores running 28-31C when idle/ broswer and skype running (kinda the same thing i guess)
    Now if only I can solve the RAM failure and why AVG and Windows Defender won't run then I'm good
