Cooling Idle temps can't possibly be right + Kaput under Intel Burn Test
Discussion in 'Hardware' started by Mac_Trekkie, 5 Apr 2012.
  1. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    Got an i5 2300 sitting under a Scythe SCSK-1100 cooler and I'm staring at it idling at 31*c. That can't possibly be right. The cooler is exposed to open air(case lid off) and sitting on Arctic Cooling MX-2 paste. Under Intel Burn Test the graphics fizzle out (i5's integrated graphics) and the screen is a hash of static with the actual graphics output barely visible under that but the computer seems to have frozen. However it can complete a few passes before that happens and load temps don't seem to go above 60*c before it all goes to hell. Could we possibly have gotten one with a bad graphics die? It's in a 2u rackmount case with about 5mm to spare above the cooler's fan. It idles at 36*c with the lid on. I'm in the process of drilling holes in the case for it to breath better, but it will still do the graphics going haywire thing with the lid off.
    Cooler here: http://www.newegg.com/Product/Product.aspx?Item=N82E16835185097
    Any help would be appreciated.
    I can try it with a dedicated graphics card, would that help both lower temperatures and stop the breaking under IBT?
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    Is the cooler making proper contact? Make sure the pins are going all the way through the mobo?
    Are you sure the CPU is 100% working?
  3. Mac_Trekkie
    10 Sep 2011
    The cooler is definitely secured properly, I can't push the pins in any further and it's perfectly level with the motherboard. Unfortunately I don't have another LGA 1155 computer to test the CPU with.
  4. Taniniver
    Taniniver Minimodder
    24 Aug 2010
    The temps seem reasonable I guess, is it overclocked, and what's your ambient room temperature there?
    I've got the 2500K clocked to 4.4 GHz (no extra voltage) cooled by a ThermalRight Ultra 120 eXtreme, and that runs in the high 20's to low 30's at idle, depending on room temperature in the range of about 19-24 C. Full load is mid to high 50's.
    I've never tried stress testing the integrated graphics though, the most they get used for is driving a secondary monitor and no gaming.
  5. boltonuk007
    boltonuk007 What's a Dremel?
    29 Sep 2011
    isnt the idle temp irrelevant with these chips? What I mean is that no matter what the overclock is then the idle temp will always revert back to a standard temp because the multiplier drops when full power is not required?
  6. Taniniver
    24 Aug 2010
    In general yes it will drop, but not necessarily to the same level as it would with no overclock - it depends if you modify the voltage, and if you disable any of the features in the BIOS to do with power saving, sleep states etc...
    I know for high overclocks many people swear by disabling these features for the sake of stability, personally I prefer to just go for the best overclock I can manage without disabling them and with no extra voltage (or maybe just a little extra...)
  7. boltonuk007
    29 Sep 2011
    but the voltage wont be used when idle anyway. it will call upon that voltage when needed? correct me if im wrong
  8. Taniniver
    24 Aug 2010
    Again, it depends on the BIOS options. In general it will reduce to a lower voltage at idle (mine certainly does) but if you changed certain settings I think you could make it run at the set voltage all the time.
  9. boltonuk007
    29 Sep 2011
    ok, fair enough, thanks
  10. TobletDanillio
    TobletDanillio Minimodder
    7 Jan 2012
    what are the fan settings like? turn the fan up?
  11. rollo
    rollo Modder
    16 May 2008
    Furmark will stress the graphics part of the chip
    If it doesnt work then the CPU is broken most likely
  12. Pookeyhead
    30 Jan 2004
    I fail to see what's so shocking about 31 degrees. Idle temps don't mean diddly squat anyway. What's it like being hammered? That's what matters. The delta between ambient and idle is irrelevant. Mine idles at 37 now the weather is warmer. So what?
  13. Mac_Trekkie
    10 Sep 2011
    If you read the first post, it breaks when it's being hammered.
    Maybe I'm just used to my i7 870 which idles at that now at 4.2ghz.
    And the fact that this is a much beefier cooler than the intel one, so it should get suitably more beefy cooling done.
  14. Pookeyhead
    30 Jan 2004
    If the graphics are going mental at 60C I doubt temps are the problem here.
  15. docodine
    10 Feb 2007
    Yeah, that's why I think the CPU (or something) is damaged.. Should run perfectly fine at 60C.
