Windows IE & bit-tech problem
Discussion in 'Software' started by reflex_1, 18 Oct 2007.
  1. reflex_1
    reflex_1 What's a Dremel?
    24 Mar 2004
    Hi,
    been having this problem for a few days now, where i go to click on either the back button in IE or on my mouse or click a link to a post and then Internet Explorer shuts down and then re-starts :sigh:
    it only seems to happen with Bit-tech though :jawdrop:
    using Vista 32bit
    all updated
    any ideas why this would be happening?
    thanks
  2. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    There's a very simple solution. Download it, install it, run it, and you won't have a display problem with a standards-compliant website ever again. Not to mention the security upgrades...
    Aside from that, I really don't know. IE is wired into Vista tightly enough that I can't see how to uninstall and then reinstall it.
  3. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    ROFL. That was classic. And true!
  4. reflex_1
    24 Mar 2004
    the Fox is now Fired up :thumb:
  5. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Welcome to the internet!
  6. capnPedro
    11 Apr 2007
    People often spring right to suggesting FF (don't get me wrong, it's a good browser).
    But if you're changing anyway, you may want to check out SeaMonkey and Opera while you're at it. Yoiu never know, you may like one better.
  7. GoodBytes
    20 Jan 2007
    SeaMonkey is well Firefox bloated with e-mail program and such (ie: Netscape.. well it IS netscape)
    Just get Firefox or Opera... Opera is faster then Firefox, but I heard it has issues with certain webpage as it reads HTML too strictly, more over has plug-in issues with some plug-ins? Flash?.
  8. Snowball
    Snowball Star Gazer
    29 Jul 2007
    *Hugs*
    I love Opera^^ And I use SeaMonkey on the few sites that don't want to work with Opera(mostly upload stuff)
  9. RTT
    RTT #parp
    12 Mar 2001
    rofl :D
  10. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    What's this "Bit-Tech" you speak of? o_O
  11. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
  12. RTT
    RTT #parp
    12 Mar 2001
    You'll note, however, that the vast majority of the errors are to do with adverts and also the majority of the forums HTML markup is generated by vBulletin :)
  13. Fophillips
    9 Oct 2006
    Excuses, excuses...
  14. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    OPERA OPERA OPERA OPERA OPERA OPERA OPERA OPERA OPERA OPERA OPERA OPERA OPERA OPERA
    i cannot reccomend it highly enough its fantastic just make sure you turn mouse gestures on
  15. GoodBytes
    20 Jan 2007
    Mouse gestures are useless, when you have a gaming mouse, or a mouse with lots of buttons conveniently placed like the Logitech MX Revolution. Beside you can have them with Firefox, there is an add-on for it.
    And unlike Opera, it's configurations are not dump in disorganized list. Moreover 99.99% of all the options in the list are totally useless. And when you want to look for something... well good luck there are over 50 pages or options, and NO DESCRIPTIONS. So you have to guess, and sometimes a restart of Opera is required, so you lose where you were on the page. Very annoying.
    And after ALL those features, you still have a lack of features, like putting the address on bar on top of the tabs like in Firefox. Now I know what Opera tried to do, and is logical, but feels very weired. I was never been able to get used to it.
    And they are other customizable features that should be there, but are not in the super long list. I find installing and configuring Linux easier then Opera.
  16. capnPedro
    11 Apr 2007
    Not really.
    When installing, you don;t have to install the mail/IRC client/address book etc.
    And SM has a smaller footprint than FF, lacks the memory leak and isn't bundled with as much feature creep.
    IMO, SM and FF were forked at just the right point. SM kept all the best parts of Netscape/Moz Suite, while FF started to gain crap.
    Sure, they're based on the same core (Gecko/Netscape) but I feel that FF is nowhere near in the same league as SeaMonkey.
  17. Techno-Dann
    22 Jan 2005
    I've used both. To be honest, as a semi-casual user, I can't feel the difference.
  18. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    Nope, in order of competence with flash it goes:
    Opera
    Safari on windows
    IE7
    Firefox
    Safari on mac
    Based on the frame rate of the same clip in each browser.
    Also, opera is better than FF for the average user. If I was going to set up someone's computer for them and they weren't that clued up about the internet I would go for opera, but Firefox is by far the better for someone who wants to seriously get into web design and development or just wants a bit more control over what they see on the internet.
    Also, opera being too strict is not a problem of operas, it is a problem with web designers not doing their job properly.
  19. Snowball
    Snowball Star Gazer
    29 Jul 2007
    I'd say its the reverse. Opera is best optomized, Firefox and IE run out of the box.
  20. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I would disagree. Opera has way more features out of the box. Firefox can have more features if you add them. I run Firefox with 20 extensions!
    I could not manage without some of them (mouse gestures which opera has out of the box; foxytunes) some are quite cool (weather) and others I could probably do without (DTA). Oh, and then there's FEBE to back them all up :clap:
