Peripherals If a USB device shorts out will it damage the computer?
Discussion in 'Hardware' started by Cthippo, 13 Apr 2017.
  1. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I've been doing a lot of messing around with underwater photography recently and am starting to run into issues with the closed architecture of the camera system I'm using. One option would be to put a camera in a waterproof housing and use that instead of the purpose built underwater camera I have now. Problem is, my amusing will be homemade and may not be as waterproof as I might like.
    I'm going to get one or more cheap webcams at the thrift store to experiment with and I totally don't care if they get destroyed. However, if, in the process of their destruction they short out the computer they are attached to, that could be problematic.
    So, the question is, can a USB device shorting out damage the computer it's attached to, and if so, will putting a USB hub in between protect the computer?
  2. Xlog
    Xlog Minimodder
    16 Dec 2006
    Get an USB isolator, they go ~10£ on ebay.
    USB hub might work, might not. Same goes for PCs.
  3. TheMadDutchDude
    23 Aug 2013
    As above, putting it into a hub may or may not work. The worst that should happen is that you fry the USB port or stack of ports. It shouldn't cause the PC to go into meltdown mode. It would suck to lose USB ports, though...
  4. Cthippo
    7 Aug 2005
    OK, I'll look for an isolator. Thanks :thumb:
  5. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    There should be protection against shorts on the motherboard side. I think the problem starts when there is a surge instead of a short.
  6. Vault-Tec
    30 Aug 2015
    There is supposed to be protection for both.
    However, having seen this a couple of weeks ago...
    https://www.usbkill.com/
    I'm a little concerned. Thankfully I never let dbags near my PC but yeah, not cool.
    I've lost a controller before. I bought a memory card reader (an Akasa too !) and it shorted one day and killed an entire internal header.
  7. wolfticket
    19 Apr 2008
    This bus powered USB hub (according to the specs) includes:
    https://www.amazon.co.uk/Hama-USB-2-0-Hub-Bus-powered/dp/B0017X0R20
    There are a few available that claim similar if you search something like " usb hub "short circuit" ".
    I'd still be wary about dunking a cable connected to an expensive motherboard/PC into water though.
