Graphics If I buy a GPU from Germany...
Discussion in 'Hardware' started by Zener Diode, 21 Jun 2013.
  1. Zener Diode
    Zener Diode User Title
    13 Sep 2009
    ...are there any major differences from the UK version? It turns out that Amazon.de works out cheaper for me than Scan or other UK retailers, and I happen to speak German, but maybe it will hurt the reselling value.
    Sorry for the silly question. I want to pull the trigger on a GTX 770 but it's a lot of money :blush:
    Thanks
  2. AlienwareAndy
    AlienwareAndy New Member
    7 Dec 2009
    It'll be the same.
    Zener Diode likes this.
  3. Zener Diode
    13 Sep 2009
    Cool, thanks :thumb:
    That's all I needed to know, and you've put my mind at ease :rock:
  4. faugusztin
    11 Aug 2008
    Warranty will be honored according to German law, and in case of RMA you will have to send it to Amazon.de for fixing (unless it is a 3rd party seller, in that case you have to send it to seller, unless the card manufacturer allows a different RMA option).
  5. Zener Diode
    13 Sep 2009
    Thanks faugusztin, that sounds good to me :)
  6. AlienwareAndy
    7 Dec 2009
    Most RMA bases are in the EU now any way tbh. Asrock and MSI are in The Netherlands and EVGA are in Germany.
  7. Uxon
    Uxon Member
    14 Dec 2010
    Out of curiosity which one are you going for? :)
  8. Zener Diode
    13 Sep 2009
    I've never had to RMA anything before, so let's hope :D
    I'm not 100% sure, because part of me is saying a 670 will do. Probably the EVGA GTX 770 SC with ACX cooler
  9. jinq-sea
    15 Oct 2012
    That seems like a decent price (and an excellent card suggestion)
  10. Uxon
    Uxon Member
    14 Dec 2010
  11. MSHunter
    MSHunter Well-Known Member
    24 Apr 2009
    Has any one tested these on 1440p? do they need 4GB like the 600 series?
    THink it was Cryis 2 with Hi textures all maxed and witcher 2 on max that past the 2GB limit.
  12. Zener Diode
    13 Sep 2009
    Hmm.. I already have the order in with amazon. I could probably cancel it but dabs has a woeful reputation in Ireland. I tried to make an account on dabs.com but it seems they want me to use the dabs.ie site, which doesn't seem to have the offer. I appreciate the heads up :thumb:
    I'd personally consider 4GB if I was gaming at 1440. I'm not sure how valid this concern is, but with the next gen consoles on the way some of the new games might be more taxing. Here's some reviews though, so far it seems to do quite well even at higher res:
    Reference card - Bit-tech
    Reference card - AnandTech
    Gigabyte Windforce 3x - Hexus
    EVGA SC ACX - guru3d
    Here's EVGA's 4GB classified 770
  13. AlienwareAndy
    7 Dec 2009
    Dabs has a woeful reputation everywhere. They would, they're owned by BT :D
    I ordered a 7970 from them last year. At first my CC bounced (£439 was a lot of money it worried !) so I phoned Dabs.... Told them not to try charging the same card until I had it sorted out. Three minutes later I get an email that tried charging the card again and failed.
    Phoned them again, went through it all again (please cancel the order etc) got another email attempting to charge the same card again.
    In the end it took three days of jostling and arguing before they finally sorted it.
  14. Zener Diode
    13 Sep 2009
    That kind of thing scares me :eeek:
    When I'm buying cheaper gear, I'll shop around for the best price and everything usually works out fine, but this 770 is probably the third most expensive single item I've ever purchased, so I really don't want anything to go wrong. I've used amazon a lot and I've never had a bad experience, a cracked cd case here and there, but nothing major.
  15. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    Dabs have always been really great for me, and they have a good and efficient RMA process, unlike certain shops who are past winners of the CPC awards...
  16. Zener Diode
    13 Sep 2009
    UPDATE TIME:
    The card arrived :D Looks better in real life, compared to the pics and videos. I had to throw the old nemesis at it, Crysis. Everything maxed out (@1080 with 16x AA), it ran smooth. It's awesome :thumb:
  17. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    I thought it'd have a bit of a breakdown myself.
    *gets coat and leaves*
