Blogs If Mad Men had computers
Discussion in 'Article Discussion' started by Sifter3000, 26 Jul 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. robots
    robots What's a Dremel?
    27 May 2010
    heh
    The 1960's called, they want their coffee table back.
  3. Valver
    Valver I’m an AquaTuning product tester
    12 Jun 2008
    Err, how do I get my DVDs in and out? Fail.
  4. Lance
    Lance Ender of discussions.
    6 May 2010
    Man up and stop using DVD/CD.
    Loving the retro look.
  5. Sifter3000
    11 Jul 2006
    Fixed that for you ;)
  6. Teelzebub
    27 Nov 2009
    Mad Men DO have computers, At least I have one :worried:
  7. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    i also have not just one, but several computers and am confirmed diagnosed shizophrenic. Proof that we do indeed have computers.
    At least i thought it was a computer last time i checked, i'm mad, i can't be sure!!
  8. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    Ummmm.... you use a USB/eSATA/FireWire based DVD drive. I no longer put a DVD RW in my PCs. I have about 4 USB DVD burners.
  9. Faulk_Wulf
    Faulk_Wulf Internet Addict
    28 Mar 2006
    Okay, even the major oversight of no optical drive or front mounted / accessible USB ports pales before this question: How do you turn it on?
    This *is* a great solution to Media Center and Server PCs however, and I like that it's minimalistic and functional.
  10. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Actually, this is a test to see who has reading comprehension skills. Looking grim so far. LOL
    "Right now Jeffrey claims the case is 85 per cent done"
  11. delriogw
    delriogw What's a Dremel?
    1 Aug 2007
    several computers hey? one for each personality?
    (i'm sorry i had to)
  12. Teelzebub
    27 Nov 2009
    :lol:
  13. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Nice case :)
    If like when I removed the power switch from my GF's pc due to her just holding it down when she was finished instead of actually shutting down... you can set the pc to switch on via a mouse click or keyboard key or even a password on the keyboard, which is then setup in the bios (depends on the motherboard of cause, but quite a few have this feature).
    So there is no need for any actuall power button. Although its a pain reaching to the rear if it does crash, thankfully not often.
  14. [- pio -]
    [- pio -] Minimodder
    2 Feb 2004
  15. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    Maybe you slide the case out from the back and turn it on, then slide it back in. Doesn't appear that the case is locked in at all. Just a nice retro styled PC case holder.
  16. devilxc
    devilxc Biding my time...
    23 Mar 2010
    "This "non-project" will be built around a Silverstone TJ08. It is a steel case that fits micro-ATX motherboards. I have no intention to spend money on computer components for this rig. My design will have no provisions for optical drives, USB ports, ventilation ports or anything else that supports imaginary installed equipment. I will however design it so these things can be easily backfit if required. The vent system will be custom built to whatever ends up inside...if anything."
    - from the project log.
  17. slipperyskip
    slipperyskip Member
    26 Oct 2003
    ^^^That is exactly why you won't find this "project" in the Project Log section of the forums. I left open the chance that it might be good enough to attract sponsors but that went down the toilet when it was published in an unfinished state.
  18. robert69
    robert69 What's a Dremel?
    23 Jul 2010
    optical disk support could be done by simply putting some hidden hinges on the front panel.
  19. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Anything is possible. I was toying with the idea of converting an old rotary phone into an external optical drive. Have it sitting on the tabletop attached with a cloth-wrapped USB cable. That way I could use it for my Mad Men II project.
  20. robert69
    23 Jul 2010
    I like that idea, though you may find the old phones are expensie.
Tags: Add Tags
