News IGPs will die-out by 2013, say researchers
Discussion in 'Article Discussion' started by Sifter3000, 7 Mar 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Slyr7.62
    Slyr7.62 «ŚŁÂŶÈŘ»
    14 Dec 2007
    2013 is 4 years away, and also, that's after "2012". 'nuf said.
    p.s. the last sentence that goes "....thoughts in the forums" doesn't seem to have a link.
  3. Goty
    Goty Minimodder
    13 Dec 2005
    Am I the only one that considers a GPU on the same die with a CPU and IGP? It's still integrated, just not on the chipset =P
  4. p3n
    p3n What's a Dremel?
    31 Jan 2002
    the IGP moves from the chipset to the CPU ... its still there ... wish I had a job researching the obvious :<
  5. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I am not a fan for integrating the gpu into the cpu for desktops for the simple reason that it means you have to have at least two different types of socket.
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    My first thought was that by 2013 our office apps will have developed to the point where they need a super GPU that's just too hot and power-hungry for an integrated solution... :rock:
  7. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    so right now you can take a motherboard with an IGP and remove it? oh wait you cant so a CPU with a GPU is not an IGP lol but yes once CPU become common place with some for of a GPU with it then of course there will be no need for an IGP except for maybe systems with say a VIA cpu unless they plan to do the same thing.
  8. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Well hopefully, if they do end up integrating videocards into CPU's, they'll at least be mid-range powerful, rather than poor-as-hell.
  9. nicae
    nicae What's a Dremel?
    25 Nov 2008
    A kid with a crayon draws images better than Intel's mid-range graphics solutions.
  10. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    Actually, that's intel's next plan: supply 20 asian children for in the basement that draw etch-o-sketch panels.
Tags: Add Tags
