Development IIS + Apache 2...
Discussion in 'Software' started by Nath, 15 Jul 2004.
  1. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    OK I'm trying to set up a local webserver with php and mysql to host my website, and i've got a book (yes they still exist, not everything's digital :hehe:) on php, mysql and apache which had a cd with them all on. So I installed apache first, and it went on fine, but when try to visit localhost I get the Microsoft IIS blurb and it seems like microsoft's already got the IIS server running. Is there any way I can turn this off so that I can use Apache on localhost?
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    Why not just uninstall IIS?
    Easiest way of doing it!
  3. Nath
    28 Dec 2003
    is IIS used for anything important?
  4. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
    IIS is the M$ (inferior) equivalent of Apache. You've got both running. Obviously IIS is starting first at boot, probably because it's M$y, so is grabbing port 80, and then blocking apache from running.
    Prob best thing to do is, as Atomic said, uninstall IIS. (Control Panel - Add/Remove -> Windows Components -> IIS.) :)
    Of course you could just change the port of one of them and have them both running concurrently, but why on earth would you want to do that? ;)
  5. Nath
    28 Dec 2003
    thanks very much guys! :rock:
  6. Atomic
    Atomic Gerwaff
    6 May 2002
    IIS sucks, unless you want to use ASP.
  7. Nath
    28 Dec 2003
    can't you use asp and asp.net with apache and other webserver software?
