Case Mod - In Progress Il•lu•sion - Worlds Smallest Watercooled Pico Itx, Watercooled Shuttle & LCD Screen!
Discussion in 'Project Logs' started by Mojo, 5 Jan 2012.
Do i add in a 7" screen to the facia as well?
  1. Yes
    83.3%
  2. No
    11.9%
  3. I have a better idea...
    4.8%
  1. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    This is looking pretty sweet! :thumb:
    Do you have any more details about the screen?
  2. peteski
    peteski long live the pc
    8 Jun 2011
    looking great mate cant wait to see more :rock: :rock: :rock:
  3. Combatus
    16 Feb 2009
    Great idea using metal weld+TIM. Let us know how this performs - I'll probably have to attempt to do something similar with an ITX project I have planned as I want to water-cool the chipset and vrms.
  4. ch1nb34rd
    ch1nb34rd What's a Dremel?
    12 Jan 2012
    great job so far, cant wait to see it finished
  5. Mojo
    Mojo Multimodder
    18 Nov 2011
    Was an ebay special... will see what i can muster up :D
    Roll on the next update shortly then :p
    Well so far.. very well.. the pico unfortunately doesn't have bios stats for temperature so i need to reply on the fan controller to give me a temperature further down the line :)
  6. Mojo
    Mojo Multimodder
    18 Nov 2011
    Almost finished the watercooling loops last night!
    Graphics card waterblock in - over an hour and a half to fit the bottom barb properly!
    Theres a aluminium pipe in both top and bottom to prevent kinking of the pipes.
    Top barb took 20 mins. :thumb:
    Just call me mario!
    The zip ties will later (at somepoint) be replaced by a aluminium holder.
    Can you now understand why the graphics card pipe doubles back on itself?
    makes a nice tidy solution i think! :D
    Not as tight as i thought it would be at the point... it gets worse as soon as the power supply goes in! :duh:
  7. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Wow, it looks amazing mate. The coil around the tubing just gives it an extra bit of class :D.
  8. Mojo
    Mojo Multimodder
    18 Nov 2011
    The theme is black, silver and red.. so tried to implement it best i could whilst keeping a sort of uniform look about it. I'm still not sure.. but we'll see how we progress :D
  9. peteski
    8 Jun 2011
    love it mate it's coming along lovely :rock: :rock: :rock:
  10. Kyukuru
    Kyukuru What's a Dremel?
    20 Jan 2012
    Watercooled in that small thing!!!? You're crazy man, my kind of crazy!
  11. Mojo
    Mojo Multimodder
    18 Nov 2011
    :D thank you!
    :rock:
  12. Mojo
    Mojo Multimodder
    18 Nov 2011
    Power supply...
    How the power supply started out less some of its connectors!!
    I didn't like the fact that previously all the atx cables were grouped together
    So lets roll on the hard work!!
    The power supply and mess mid work!
    Ha look at that mess!!
    But amongst all that chaos is some good principles. Precut shrink in place and all the tools I need within easy reach!
    Note that the lid is off? this is so that i could shrink the heatshink inside the casing as well.
    Not everyone does this but i want to take the time and effort to make sure this is done right.
    The casing is also bent back so that i could get my fat fingers in there :lol:
    This is corrected when putting the casing back on.
    Num num num!
    Lots of sleeving!
    Every end heatshrinked
    The sleeving in place and tidied.
    Its also been placed to sit just below the hard drives.
    The cable was secured with a 1inch sticky pad and zip tie.
    Graphics cables in place.
    Chose for these to be grouped for ease (this may change)
    The heatshrink acts as a stress reliever for the cable.
    it runs along the front panel.
    The cable has been arched in such a way that i can still access the screws for the drive bay if i need to. Its something simple but makes life so much easier later down the line!
    Graphics cable held in place with zip ties
    Looks nice and tidy and out of the way!
    Bulk of the other cabling up and out of the way hidden from view.
    Made a slight mistake and made the 4pin atx connector cables too short!
    So that's another project later on in the week
    Also need to find a black connector for this :)
    I've also yet to do the sata power cables as i need 2 drives to work out how far apart the connectors must be. This will be done later on in the project :)
  13. yassarikhan786
    10 Aug 2011
    Looking fabulous if I do say so :D.
  14. Mojo
    Mojo Multimodder
    18 Nov 2011
  15. Fanatic
    Fanatic Monimidder
    4 Jun 2010
    Real shame you lost the drive to finish this mate, was following progress with interest. :waah:
  16. Mojo
    Mojo Multimodder
    18 Nov 2011
    The bulk of the project will continue... the shuttle will still be watercooled.. its just going to lose the pico. This isnt just because i've lost interest but because finances have taken a plummet making the project what it is.. i simply cant afford to finish it without some help! :)
    There isnt anything to say i dont have a sneaky idea up my sleeve though!!
  17. Fanatic
    Fanatic Monimidder
    4 Jun 2010
    Stop buying everything under the sun in the marketplace then!!! Hehe! :D
  18. Mojo
    Mojo Multimodder
    18 Nov 2011
    Thats just so i can fulfil the remainder of my projects!!!
    The shuttle has taken front place in all of the projects..
    Then htpc
    Then nas
    All the hard drives for everything will be paid for on pay day..
    So thats - 2x 64gb Corsair GT60 Red SSD's -£140
    750GB 2.5" Sata - £50
    2TB - £65
    From that i can finish off the shuttle, htpc and nas :)
  19. theoeyeo
    theoeyeo What's a Dremel?
    27 Nov 2011
    wow, lucky you're atill getting cheap prices on hard drives. I had to downgrade to a 1TB which was the same price as 2 when i started my project :sigh:
  20. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    Sorry to hear about the car and the sale of parts of this mod, was looking really good.
    Could you tell me where the 7" screen and control board where from? I would like something similar in the near future.
