Modding Illuminate Your PC - Part 2
Discussion in 'Article Discussion' started by brumgrunt, 9 Feb 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Nice guide Antony :thumb:
    picture links are all wonky on the second page
  3. McDuff32
    McDuff32 Minimodder
    5 Aug 2011
    Woow, cool guide!!
  4. feathers
    feathers Minimodder
    11 Apr 2009
    I purchased an M1 tank spotlght on eBay for $400. I am using it to light my PC but the problem is I can't run it for more than 2 seconds without the PC getting extremely hot. What can I do?
    xxxsonic1971 likes this.
  5. The Bodger
    The Bodger What's a Dremel?
    26 Dec 2003
    What sort of bulb does it use? I'm guessing something that runs on 12V and is about 50 - 100Watts? I can only think of one practical way to solve the problem, and that is to install a bulb which generates less heat. I'd suggest that you look into whether you can buy a sufficiently bright LED based bulb that fits. Failing that, you may be able to buy and dismantle a 12V LED based spotlight / downlighter bulb and mate it with the metal fitting off the original bulb from the lamp.
    Using a high power LED 'bulb' would allow you to get down to between 1 and 5 watts, which would reduce the heat by a factor of at least 10.
    Regarding the article, one thing that I don't think has been mentioned is the possibility of engraving the acrylic; with a bit of care, some very attractive effects can be achieved by adding engravings to the illuminated sheet. Rather than masking and spraying the acrylic, if you have the tools you can engrave and in - fill to get a similar effect, and it is less prone to getting rubbed off / worn away. Obviously though, you only get one shot at that... not for the faint hearted!
  6. skreenname
    skreenname SFF Forever
    11 Jun 2009
    Neat article,never thought of cutting just a slot or something into the case panel, neat idea!
  7. Tangster
    23 May 2009
  8. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    great article!
  9. Mr_Armageddon
    Mr_Armageddon Minimodder
    31 Jul 2009
    Really liking these guides. I am actually getting ready to do an illuminated mid-panel for my system, so the more info I can read on the subject, the better.
  10. alamoqqvv
    alamoqqvv What's a Dremel?
    12 Feb 2012
  11. Combatus
    16 Feb 2009
    Sorry about the images on the second page guys, somehow the numbering had got out of sync - all sorted now!
Tags: Add Tags
