Guide Illuminated Flooring - How To
Discussion in 'Modding' started by Skorchio, 3 Feb 2010.
  1. Skorchio
    Skorchio What's a Dremel?
    16 Oct 2009
    If you have been following my filtration project closely you would have seen all my R n D on this flooring but I finally (after about 2 months playing around with LEDS and CC’s) found a product that would give me exactly what I need and they are Electro Luminescent panels.
    To get a custom made panel to fit the base of the TJ07 it would have cost way over £200 so I opted for 2x A4 size panels at around £50 each.
    They normal run off 240 volts with a 12 adapter, perfect all i need to do is a slight molex mod.
    As you can see below the 2 panels where different shades, cut a long boring elecci tecki talk, I needed to run both panels off the same inverter. So all I did was cut the cable and solder it back on to the other inverter (keeping the wires the same length).
    This solved my colour problem but now as i d taken the cheap route and opted for 2 panels you could see where they joined and this was not good enough. I was always going to run a diffusion filter over the top of the panels to soften the light but this would only hide the line when it was 13 mm off the panel, hence me having to raise my floor like I have (although I like how it looks this high).
    And there you have how I did it :D Remember you can put any colour filter over the top and create any coloured glowing floor. Or even lay a shape or logo on the EL panel and the shadow displayed on the diffusion filter, the possibilities are endless.
    Please pop over and take a look at my full project log. The links in my sig.
    Skoch
  2. capnPedro
    11 Apr 2007
    That's a fantastic effect!
  3. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Thats awesome.
    +Rep
  4. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    one word
    STUNNING!!!!!
  5. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
  6. stonedsurd
    11 Mar 2009
    That's magical mate. Thank you for the guide :)
  7. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    can u drill or cut the plates ??
  8. Skorchio
    16 Oct 2009
    wow thanks for all the kinds words.
    Lenne yes you can, more some than other, watch the log to get a better idea :)
  9. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    That is awesome bro!!! Excellent job there! I watched this before while you were working on it but I couldnt resist to post here again!! Mod on bro and come over to Cyprus to mod together one day!! :) Peace!
  10. migasmahn
    migasmahn What's a Dremel?
    9 Feb 2010
    Holy Smokes..... Crazy effect i love it
    Thanks for sharing :rock:
  11. Skorchio
    16 Oct 2009
    Thanks guys
    Showing how they can be cut
    Wala!! It worked and now i can can clean the mess in my pants :)
    Here is the back of the panel, them two strips are the only bits you cant cut (to an extent)
  12. el2k
    el2k Modder
    18 Jan 2010
    That looks awesome man!
  13. Pog_Frog
    Pog_Frog What's a Dremel?
    1 Mar 2010
    Very nice mod!
  14. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    where did you get the panels from?
  15. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Nice work :thumb: I didn't know such a product existed, which can be cut out like that and still glow nice and evenly :rock:
  16. merple
    merple What's a Dremel?
    18 Dec 2007
    I think the EL is from Earlsmann.
  17. Tasslehoff
    Tasslehoff What's a Dremel?
    25 Jan 2010
    What an excellent idea
