Modding Illuminating Coaster *with pics !*
Discussion in 'Modding' started by Hippo, 8 Sep 2003.
  1. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    You have to get a fine balance and just on its own isnt enough to press it. I suppose that depends on the material you choose for the switch thou.
  2. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Cheers for that dude. As said above. you powering from PSU or something else? my initial idea would be to power from something like USB or perhaps even a 9v battery for portability ;)
  3. Hippo
    7 Mar 2003
    Im currently powering it from a Plug-in-the-wall power pack thingy, you know the type. However USB should be ok, you'll just have to connect the LED's in parallel - USB only being 5V. Also check the current rating for the USB port you plan on running then from.
    I decided against batteries because of a size thing. To get a decent mAH i would have had to made a huge coaster with a nice battery compartment :hehe:
  4. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    alll the pics are dead for me and from the sounds of it, it looks cool
  5. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    You added a whole new dimension to my morning cup'o'coffee. Now I feel good and the coffee looks good.
  6. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    i had one of those credit card torch things (but i lost it :waah: ) it ran off 3 little button/watch batteries and had 2 super bright led's in it :)
  7. Shogun
    Shogun Banned
    18 Jul 2002
    how many leds are you using? I can only spot one? :worried: . Would i be able to get some copper tape off you? I dont think i can solder to alu tape?
  8. Wreckless
    Wreckless What's a Dremel?
    14 Aug 2003
  9. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I can just see everyone on the forum building one of these, AOL disks could come in handy. :thumb:
  10. death_star
    death_star What's a Dremel?
    14 Jul 2003
    No send the aol discs to no more aol discs
  11. Astrum
    8 Mar 2002
    No, it's such a waste just sending them back (if they get their target number). Make them coasters! :rock:
    It would be cool if you could power the LED's from the heat of the cup (wouldn't work for cold beverages though). Peltier effect is what it's called I believe.
  12. Chief752
    Chief752 What's a Dremel?
    3 Sep 2003
    Great job Hippo! This is my first post here, but I wanted to let you know (all of you here) how much I've been influenced by the guides and advice I have seen on this forum. I have started my own mod and will post pictures of it when its done.
    Keeping coming up with these fantastic ideas. It keeps me busy in my old age. :D
  13. MaSHim0t0
    MaSHim0t0 What's a Dremel?
    8 Sep 2003
    damn nice, be nice to use it on a glowing mouse pad too
  14. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    zap in order to make it a challenge you are required to add thermal monitoring. you need to knw if your prefferred bevvy is at the right temperature...
    j/k
    Yeh a pair of cr2023 batteries (the number may be off, thw kind that your motherboard has if it is post 1998) should power four leds... and would not raise the size or circut requirement much.
  15. VadimtheConqueror
    VadimtheConqueror I love the little tacos...
    10 Jul 2002
    you know, an rgb led with that, the colder it is, the bluer it is, the hotter it is, the redder, would be kind of cool
  16. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Sounds like a good idea.
    (Which I don't have the time for right now)
  17. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    I actually thought about using a thermistor in mine too. I was thinking more like when it's warm (or warm-ish) it gets red, and when it's cold it gets blue. I just need a circuit that can switch between two LED colors using the varying resistance of the thermistor.
  18. Astrum
    8 Mar 2002
    I'm suprised you sleep with all that you do.
  19. ZapWizard
    19 Sep 2002
    notes it's midnight.. the wife is asleep already.
  20. apoogod
    apoogod trix arent just for kids
    19 Jun 2002
    just wondering what type of acrylic was used?
    great job btw
