Networks im a n00b [smoothwall - ahh]
Discussion in 'Hardware' started by neuro, 2 Mar 2002.
  1. neuro
    neuro What's a Dremel?
    9 Jan 2002
    ok - i tried to setup smoothwall but fail miserably. any one who has setup smoothwall on a cable connection (im with blueyonder) please, i need help or tuturials on how to set it up. i mean word for word bcoz i completly suk!
    for the love of god....
  2. ToM
    ToM mmmm, blud
    14 Aug 2001
    whats smoothwall?
  3. ChriX
    ChriX ^
    30 Aug 2001
    Smoothwall is a linux based internet firewall OS thingy. I've been using it since the start of this year - its great!
    Sorry, I cant help you with setting it up for cable cos im on 56k (god help me) :(
    I shall move this thread to the Networkin' Forum, because you should get more attention there :)
  4. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    Sorry i can't help much...but i heard it was easy to setup, even if you have no experience of linux. I may try soon, when i get a spare pc:D I looked on the smoothwall site, abd there are some pdfs that go through what to do.
    When you say you failed when did you fail?
    Charlie
  5. Tim S
    Tim S OG
    8 Nov 2001
    The way that I would do it, and have done it, is to install 2 network cards into the main system (either 3 com or a realtek based card is garaunteed to work)
    U need to set one card (the one connected to the cable modem) as the red network...
    and the other card (your connection to your hub/switch), to your green network.
    u need to leave the red network card to get its IP automatically, and you need to set the green card to something like 192.168.1.1, and enable DHCP so that it can assign IP addresses from 192.168.1.2 to 192.168.1.100, and give a lease time of say, 120 minutes, this means that it checks that the node is still there every 2 hours :)
    This is about all the setting you need to do on the actual server....
    Somewhere along the line you need to setup 3 account passwords, the first two will be used when you are sitting infront of the server... the third is for daily maintenance, known as the admin account.... you control this one from your browser on your own computer...
    next you need to goto your browser... and type the following in your address bar:
    https://192.168.1.1:445/
    (assuming that is what you chose for your servers IP address)
    this will bring you to an easy to use browser based configuration... where you can set your webcache, firewall settings, etc
    hope this helps a bit :)
  6. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    as the ppl in #smoothwall told them when i asked...
    "RTFM"
    shortly followed by
    *** Mode change "+b *!*mrplow@*.btopenworld.com" for channel #smoothwall by some_chump
    :rolleyes:
  7. Tim S
    Tim S OG
    8 Nov 2001
    hahahahaha! :D
  8. Phrozenpenguin
    11 Dec 2001
    Biggie : Is it really that easy?:confused:
  9. Tim S
    Tim S OG
    8 Nov 2001
    Well I just RTFM before installing, and the rest was self explainatory :rolleyes:
    What I have done is summed up the basic outlines as to how to do it...
  10. neuro
    9 Jan 2002
    biggie - i done pretty much every thing u sed, but the browser just wasn't findng anything. ill try again some other time.
  11. herbs
    herbs Nobody but us chickens
    7 May 2001
    Right does smoothwall detect both cards correctly?
    If so what are the ips of the cards?
    From the smoothwall box can you ping an address such as here?
    You need to provide more info.
  12. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    could anyone name some nic cards that run on a realtek chipset???
  13. herbs
    7 May 2001
    The cheap scan.co.uk ones do, or even better visit a computer fair and get some there. A lot of the cheap nics use realtek, just ask or open the box and read the instruction there you will find the information you need.
    IPCOP a spin of from smoothwall have a list of network cards that are supported.
  14. felix the cat
    11 Jan 2002
    cheers....ill have a look at the next fair...
  15. Tim S
    Tim S OG
    8 Nov 2001
    you either need some with a realtek chipset, or get some old 3coms (like I did) and it should work.... smoothwall is very easy to setup, if you have compatible hardware ;)
  16. felix the cat
    11 Jan 2002
    well ive dug my old box out, p166 96mb ram 1gb hdd, put in my two dlink cards that are running my win2k server, but smoothwall didnt like em....so i went back to my old server, but id still like to use smoothwall....
    so next time at a computer fair ill have to find some realtek based ones as i cant find any on the net and the 3coms are a bit tooo expensive....
    just out of interest, anyone done this with ntl cable???
  17. Tim S
    Tim S OG
    8 Nov 2001
    Yep ;)
    Works fine, and Im doing a second installation over the summer.... of all the networking gear, cos we are moving house :D
  18. dakar
    dakar What's a Dremel?
    6 Mar 2002
    realtek chipset
    Take a look at the D-Link 530 TX+ nic's. great cards that perform well..and at the right price (about $13US)
  19. sco0by
    sco0by Mmm pie.
    12 Dec 2001
    Quick simple question:
    Does smoothwall run on a machine with Linux installed, or is it a Linux O/S in its own right?
    Be gentle with your answers please :p
  20. herbs
    7 May 2001
    It is linux just a stripped down version removing most of the baggage and unsecure stuff. Be forewarned it takes over the completed hd that you have in the machine. Personally I think ipcop is better.
