smoke windows arent much different from clear ones, IMO....in fact, if i had the choice on the pre-made side panel on my Lian Li PC65, id get a smoked window...looks better in teh light than a clear one dows, and it doesnt block out the cathodes overmuch.
Yeah, i could send it back but at the moment the smoked window does kinda go with teh black case. - i'll keep it i think Thanks for the LED guide cheesey now, all thats left is to find out how to stealth my drives . . .
thanks, that was all i needed to know thanks for the tips people, i'll let you know how it turns out with some pics
I was going to be a virgin modder too, unfortunately there are no more virgins left in N london. :/ (sorry cheap gag but I couldnt' resist!)
hehe i was waiting for that one btw, i bought a dremmel the other day and i'm a little confused as to what all these nice disks do I've got a thin metal circular saw kinda thing , about 20 thin ceramic disks, and two very thick what look like grinding or filing disks. WHAT THE HELL DO I USE TO CUT LOVELY SHAPES IN MY METAL CASE? anyone know?
Thanks Kazza, Thats a great guide. which has posed another question. Is it worth getting heatshrink tubing? how does it work?
do you mean blowhole trim or heatshrink tubing? I have only just discovered the joys of heatshrink... Basically if you solder two wires together you then slip over some heatshrink and stick the soldring iron on it and it insulates it nicely... much neater than wrapping it in insulating tape. go to maplin and search for heatshrink
