Build Advice I'm Thinking of Buying a Prebuilt
Discussion in 'Hardware' started by wiggles, 15 Jun 2021.
  1. wiggles
    wiggles Minimodder
    9 Jun 2010
    My 970GTX is getting a bit long in the tooth and I want a new rig.
    Having seen the prices of the Nvidia 30x0 series I think buying a pre-built is the way to go. I see a few post on Hot Deals UK mentioning prebuilds by Palicomp and AWD, is this a good way to go?
    Are there any things to go for or things to avoid at the moment? I have a 1440p monitor and want something of a beast to feed that for the next few years. I have up-to £2k to spend.
    Sorry for the generic post but I feel out of the loop.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Be prepared to wait many months. My work has been waiting I think 5 months for a 3080 equiped machine from Scan.
  3. The_Crapman
    5 Dec 2011
    If you're not especially picky about exact specs, you can often get one right away. Been trying to get hold of a GPU to build my mate a rig for months, but he ended up getting a maingear or pc specialist one from Currys, next day delivery.
    Overclockers also keep some cards back for systems and you can see in the options if they have one in stock
    5600x and 6700xt
  4. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    keep in mind pre-builts are spec-ed to the bare absolute minimum, which is why you get bottom tier components at high spec'ed prices, that's great if you are desperate for a 1660 TI with a 1050 heatsink and a butt ton of bloatware
    this has been true since the dawn of the PC clone era
    yea compaq will sell you a geforce based K6/2 system but its a gimped chip running at 75MHz FSB instead of 100 + the too piss poor to make a MX version video card back in 1999
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I think wiggles was on about a prebuilt system from a proper system builder, not the generic stuff HP et al churn out so he shouldn't overly need to worry about low end components going in his rig.
  6. sandys
    sandys Multimodder
    26 Mar 2006
    Buying a prebuilt or gaming laptop seems the only way forward for many now, I've considered getting a prebuilt to strip it for parts, fortunately I'm not that desperate for hardware I have a decent system, just had the upgrade itch.
    So long as you understand what you are buying its fine.
    I saw some of the AWD-IT stuff at costco when I was in there, looked at the lower end stuff for a friend, seemed perfectly fine to me.
  7. Anfield
    Anfield Multimodder
    15 Jan 2010
    Stay away from big name brands like Dell / HP / Acer to avoid parts that are deliberately made proprietary to prevent repairs / upgrades.
    Easiest to stick to the house brands of shops like Scan, Ebuyer, Overclockers etc so you get real off the shelf parts.
    Tech Jesus recently looked inside a Dell...
    And I have to agree with him, the whole thing will be ewaste the moment something goes wrong.
    Yaka likes this.
  8. Vault-Tec
    30 Aug 2015
  9. wiggles
    wiggles Minimodder
    9 Jun 2010
    Priced up this (img) at £1450 ish.
  10. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    It's mad you can build a pc for the price of videocards.
  11. wiggles
    wiggles Minimodder
    9 Jun 2010
    This is £1223 but with a Ryzen 3600 and 3060 instead.
