Apple iMac as primary computer?
Discussion in 'Software' started by M3G4, 27 Mar 2007.
  1. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Hey all,
    Having used my macbook for a while and really enjoying the pluspoints of OSX, I'm thinking of taking advantage of the student discount and getting a nice iMac to replace the dell system in my sig. Question is, I could either get super-decent 20" iMac, or a 15.4" MBP both for roughly the same price. Considering I have a Macbook, would it be worth buying a MBP or an iMac?
    Cheers!
  2. seebul
    seebul Minimodder
    9 Aug 2005
    Get an imac, and keep the macbook, personnaly i dont think (speed wise) there is that much difference between the macbook and macbookpro. I just dont think the pros arent worth the money.
  3. Firehed
    15 Feb 2004
    I'd say get the iMac, both for the added screen size and having a proper desktop. I've got a MBP and while it's a great machine for the most part (although honestly, there are some REALLY stupid design flaws in that sort of Apple-esque form over functionality; though I find they're true on the MacBooks as well), I can't stand not having a proper desktop machine anymore. The iMac has a bigger and faster hard drive in it as well, which is always a plus.
  4. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    hah, you obviously don't own one then :p
    BUT since you already have a macbook i would be inclined to agree with the above advice of keeping it and going with macbook. unless you need 3d accel on the go?
  5. seebul
    seebul Minimodder
    9 Aug 2005
    True True :p But ive been on a couple and i havent really noticed a huge difference, maybe u have a very nice spec?
  6. Fod
    26 Aug 2004
    15.4" 2ghz 2gb 100gb - i just love the screen and the 3d graphics. makes a huge difference to me as i use it fairly heavily.
  7. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    I'd just sell the dell and get a external monitor say a 20in dell. Hook the macbook upto it and use a keyboard/mouse and you have the iMac pretty much.
    Far cheaper and you get to have the best of both worlds with very little performance difference.
  8. RTT
    RTT #parp
    12 Mar 2001
    Agreeing with gordy (for once :D)
  9. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Unless you want to play any games. I don't think the macbook could run any games at native resolution on a 20" display.
  10. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    If they have the same CPU, there is no difference between the two laptops. Get the imac TBH.
  11. cderalow
    cderalow bondage master!
    23 Jan 2002
    the primary differences between MBP and MB are the graphics and screen, the MB has integrated graphics and a 13" screen, the MBP has a graphics processor and a 15.4" or 17" screen
    processor, memory, hard drive, optical drive wise, they're pretty much the same
  12. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    MBP's look nicer too.
  13. cderalow
    23 Jan 2002
    aesthetics have no impact on performance
  14. Firehed
    15 Feb 2004
    Not if you wear a watch with a metal band. Mine's scratched to oblivion there.
  15. Fod
    26 Aug 2004
    i always take the watch off :p
  16. Firehed
    15 Feb 2004
    So do I now. But it doesn't remove the damage :(
  17. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Yeah, I'd have to have a meaty graphics card because I currently use the dell to play the Sims 2 on... and it hates it... far too slow!
    I reckon the iMac would probably be the way to go too; considering the macbook can run sims 2 fine using its intel GFX at native res (surprising, i know!), plus i've upgraded the macbook to 2GB RAM, and given it a 120GB HDD, so I reckon it's gutsy enough for everything portable I want to do. Not a massive games player, and I would have got an MBP originally if it wasn't for the dinky size and small weight of the MB (size was a primary concern when i bought it, seemed the best spec small laptop whilst also having a plus of being able to run FCP)
  18. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    Go for the MacBook, simply because it will stop you playing Sims 2.
  19. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Yay :D
    Macbook pro does look nicer, but the macbook is still a spangly thing.
  20. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    I honestly don't think the MBP looks that much better, though I do like the improved speakers, and gimmicky light up keyboard. Screen size is neither here nor there tbh, since apple brought out the MB13's, the screen resolution has matched those of most 15" PC laptops!
    Unrealhippie - shush! lol i love that game!
