Apple iMac Memory?
Discussion in 'Software' started by Guest-16, 26 Oct 2007.
  1. Guest-16
    Guest-16 Guest
    My bro just bought an iMac with basic 1GB stick of memory, however Apple charge though the nose for an extra stick but you can upgrade it yourself.
    An extra single stick of 1GB is less than £20 now, but I want to get him a 2GB stick to give him 3GB to play with - HOWEVER - will it work? Do iMac's or Macbooks go funny with mismatched sticks? (it's the same memory - ddr2-667 SODIMMS).
    EDIT: Hrmm £57 for 2GB or £17 for 1GB :|
  2. koola
    koola Minimodder
    11 Jul 2004
  3. Guest-16
    Guest-16 Guest
    but do you run a 1GB stick with a 2GB or a 512mb with a 1GB? I need to know for sure if they work mis-matched sizes.
    Is 2GB enough for OSX Leopard? Or will 3 be far better?
  4. koola
    koola Minimodder
    11 Jul 2004
    I run two 1GB sticks with no problems. Wouldn't know if different sized sticks would work correctly, but I see no reason why not.
    2GB will be fine for Leopard.
  5. K
    K 528491
    31 Oct 2001
    They run FINE like this, no problems whatsoever mate. 2 gig is plenty, but if you can go for 3 then why the hell not eh? A 1 gig stick is so cheap right now it'd be crazy not to upgrade.
  6. Valo
    Valo Minimodder
    11 Aug 2004
    or get some corsair value 2x2gb or 2x1gb sets. They go dirt cheap these days
  7. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    Backing up what others have said, pretty sure I've put 3GB into a few iMacs (1GB base, 2GB expansion, PPC & Intel) without issue.
