Modding In need of some 'black' Plexi
Discussion in 'Modding' started by Warrior_Rocker, 1 Oct 2005.
  1. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    ok, this is short and simple, and if this has been posted already, i have probably looked at it, and have not found the answer i was seeking...
    all i need is about a 12inX12in peice of black plexi glass, or shiny black plastic of some sort, so any US suppliers would be greatly appreciated, thanx in advance for the help
  2. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
  3. dubdvd
    dubdvd What's a Dremel?
    14 Jun 2005
  4. WizZard
    WizZard What's a Dremel?
    3 Jun 2005
    AC Ryan just launched some mirrored acrylic today if that's any help
  5. Warrior_Rocker
    26 Jun 2005
    thank you guys very much, i know it was a n00bie post on my part, but sometimes you gotta ask the stupid questions, thanx again
  6. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    spray paint the inside of the plexi. it will have the plexi itself in between it to keep the paint from getting scratched, and it will look perfect because all the paint blemishes will be on the other side of the plexi.
    i didn't look at any of the links, so sorry if i repeated anything. tell me if you don't get what i'm saying, i feel like i didn't explain it well. basically paint the surfact you won't be touching when it's finished
  7. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    the technique I'm not a monster is describing is rock solid, painting the back of the plexi gives you what ever color you want with a high mirror finish as the plexi acts like a thick clear coat. It simple as you don't need any prep or have to sand just paint and be done. It will scratch of easily so it has to be in places where once finished gruby hands and such won't be scratching at it.
  8. MiLwOrkZ
    MiLwOrkZ What's a Dremel?
    6 Feb 2005
    hmm... it might jsut be my distinction but i am assuming he wants it to have some sort of transparency? so in that case he needs to check out collermeister's STORM'D case!
  9. I'm_Not_A_Monster
    22 Dec 2003
    if you want it transparent, either spray a light coat on the inside, or use that window darkening film stuff
